Activity Forums Apple Final Cut Pro Legacy FCP 7 Clip into Sequence
  • FCP 7 Clip into Sequence
    Posted by Mike Gjuraj on January 10, 2014 at 10:37 pm
    This happened all of a sudden, and I did not have this problem just a few minutes ago. I am too busy to look it up, so please do not bust my chops if it is an easy fix, or a simple find on the internet. All I am asking for is help or direction from someone with more time than me.
    FCP 7 will not allow me to put a new clip directly at the end of the last clip anymore. It does not give me definite start/stop points of clips in the sequence. How do I fix this? I do not want to be dropping new clips into the TL and deleting all spaces.
    Thank you!
    Neil Patience replied 12 years, 8 months ago 2 Members · 1 Reply
  • Neil Patience
    January 12, 2014 at 12:23 am
    One possible reason for not getting clean edits or flash frames in a sequence is trying to edit H264 clips directly into the timeline.
    This often results in the kind of behaviour that you mention.
    If this is the case transcode to ProRes and you should be fine.
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 or MC V 7 with Symphony option. FCP7, Color, Media creation and conversion. Adobe Encore DVD creation and authoring.
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 or MC v7 with Symphony option FCP7
    7TB raid 5 fibre storage.
