Activity Forums Apple Final Cut Pro Legacy FCP 7 – Clean Install – ProApp 2008-05?
  • FCP 7 – Clean Install – ProApp 2008-05?
    Posted by David Fortin on January 25, 2010 at 3:48 pm
    Last week I did a clean install (re-formatted HD) of OS 10.5.8 and FCP 7. Used the Software Updater to bring everything current (except things like iTunes and other stuff I don’t use). Everything went well. Everything seems to work.
    Today, the software updater says that I need to install “Pro Applications Update 2008-05, ver 1.0”.
    The release notes states that this software is for applications with older versions that what I’m running. Such as Color 1.0.4.
    Should I tell Software Updater to install this?
    Or should I just keep ignoring it?
    Don’t know why it is telling me to do this, since I thought it had been done during the installation process last week.
    Has anyone else run into this?
    David
    Lance Lipman replied 16 years, 7 months ago 4 Members · 5 Replies
  • Todd Reid
    January 25, 2010 at 4:11 pm
    My advise, if you don’t need it….don’t install it!!!
    Todd Reid
    Senior Editor
    Digitized Media, Inc.
  • Lance Lipman
    January 25, 2010 at 7:06 pm
    I have the same issue and would hope the update would be savvy enough not to mess us up. Not certain so I’ve held off.
    Maybe holding on to LiveType is what’s doing it.
  • David Fortin
    January 25, 2010 at 7:10 pm
    Lance,
    Good point. A yearly project I work on uses LiveType. I installed LiveType after I installed FCP 7, so I’d have it available.
    That could be it.
    Thanks.
    David
  • Gary Adcock
    January 25, 2010 at 7:50 pm
    [todd reid] “My advise, if you don’t need it….don’t install it!!! “
    I totally disagree.
    the ProApps Updates were always the little fixes that can solve a number of issues.
    this one fixed a bug in ProRes capture and playback, plus a memory leak in the Color interface if I remember correctly.
    I ALWAYS recommend that you update theses updates as long as you are not in the middle of a project.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/garyadcock
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Lance Lipman
    February 6, 2010 at 8:38 pm
    Hi David,
    I installed the update without any problems. Just fyi.
    Lance
    Video Assets, Inc.
    Atlanta, GA
