Activity Forums Apple Final Cut Pro Legacy FCP 7 causing my system to stutter..?
  • FCP 7 causing my system to stutter..?
    Posted by Steve Day on February 20, 2010 at 7:19 pm
    Hi FCP users,
    FCP is causing my system to stutter. Meaning if I play a movie or drag open a regular window it stutters. I have trashed the FCP preferences and user data. I’ve re-installed FCP Studio twice and still it happens.
    I know its FCP because I have used the app ‘Maintenance’ to reset preferences and the system cache and everything works fine. I can play a movie in Quicktime and it plays as it should. Once I boot open FCP and immediately shut it down. Anything I play in QT jumps, ie, stutters.
    Any ideas on what i can do to fix this. I’ve been trying to fix it for over 8 hours but still no result..
    Many thanks for any advice!!
    Steve
    Steve Day replied 16 years, 6 months ago 3 Members · 4 Replies
  • John Pale
    February 20, 2010 at 7:53 pm
    You have not given any info about your system or the codec of the flies you are trying to play
  • Steve Day
    February 20, 2010 at 11:53 pm
    Hi John,
    Sorry your right.
    I’m on an Intel 2 x 3 Ghz Duel Core Intel Mac using OS 10.6.2
    I’ve been shooting on Panasonic P2 using the DVCPRO HD codec at 720P 25fps
    I’ve got a RAID system which has been serving me well for over a year, even with 4K files.
    The strange thing is that even when I play (mp4) in Quicktime outside of FCP I still get the stuttering.
    It seems that just having FCP on my system causes my Mac to be sluggish.
    When I run the app ‘maintenance’ which resets preferences, etc. everything behaves correctly. Once I boot up FCP and quit immediately all the system is again sluggish.
    Any advice would be greatly appreciated.
    Steve
  • Zane Barker
    February 21, 2010 at 6:41 am
    [Steve Langmanis] “The strange thing is that even when I play (mp4) in Quicktime outside of FCP I still get the stuttering. “
    Sounds like an OS or possibly hard drive issue.
    I recommend running disk warrior.
    Hindsight is always 1080p
  • Steve Day
    March 17, 2010 at 8:38 am
    I’ve had the system running fine for 4 months. Then suddenly its starting to stutter. Strange. I’ve now installed OSX on a separate hard drive with FCP 7 on there and reboot to edit. It works but what a pain.
    thanks for your advice though. Steve
