Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 bug.. beware!
  • FCP 7 bug.. beware!
    Posted by Simon Blackledge on December 15, 2009 at 8:28 am
    Spent quite a few hours hinting this little one down.
    Never have a freeze frame in TRK one at the beginning of the seq. Unless its your final master.
    To replicate..
    Make a new seq. Add a clip at say 3 seconds in. Open the clip thats in the timeline in the viewer. Goto IN.
    Create a FreezeFrame, drop in at the start of the seq before the clip you added.
    Duplicate the Seq.
    The sequence will do something funky.. either both seq will now be named -Copy
    Or the Copy will be converted to a MasterClip
    Open the copy and all media vid/audio will be named the name of the seq.. not the clip name.
    Also.. Undo Undo back to FF>Clip orig edit.
    add another clip to TRK2 above the FreezeFrame starting at frame1.
    Now select the clip in trk2 and the freeze frame at same time and nudge up a trk so they are now in trk 2 and 3
    Notice this wonderful feature in action as it renames the Seq in the bin to something else thats in there like traffic.aiff. If you don’t spot this and you have a lot of edits gets very confusing!
    Urgh!
    s
    Matt Larson replied 16 years, 9 months ago 3 Members · 3 Replies
  • Andy Mees
    December 15, 2009 at 8:59 am
    Wasn’t this weirdness specifically addressed with the 7.0.1 update Simon? Or is this one just same same but different and not fixed?
    Fixes a situation where if you edited a freeze frame as the first shot of a sequence, then edited in a second shot after the freeze frame, the sequence name would change to match the second shot.
    https://support.apple.com/kb/TS2521
  • Simon Blackledge
    December 15, 2009 at 9:27 am
    Still getting it in 7.01 🙁 might do a fresh install then.
    cheers
    si
  • Matt Larson
    December 16, 2009 at 3:43 pm
    This is one of the oddest bugs I’ve encountered in FCP… I have updated to 7.0.1 and am still having the issue. I added slug to the beginning of the sequence and that made the naming issue go away.
    You saved me a lot of troubleshooting time, thanks!
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    AJA Kona 3 (6.0.1 drivers)
    G-Speed XL 12 RAID
