Activity Forums Apple Final Cut Pro Legacy FCP 7 Boris crawl interlacing gone
  • FCP 7 Boris crawl interlacing gone
    Posted by Francois Stark on September 14, 2009 at 7:42 am
    FCP 7…
    Place a title crawl using boris in PAL. Boris does no interlacing. Makes the crawl unreadable in interlaced PAL. Tried shift fields filter… which did nothing since the fields are not inverted – there are no fields – as in boris creates the crawl in progressive.
    And I did download the boris 2.2 update – it did not solve this issue.
    Any ideas? I ended up re-doing the crawls in FCP 6.
    Francois
    Rajesh Barnabas replied 16 years, 6 months ago 5 Members · 4 Replies
  • David Bogie
    September 14, 2009 at 3:58 pm
    I can repeat this on my machine, FCP7, NTSC. It’s weird.
    Anyone talked to Boris yet?
    bogiesan
  • Bill Portune
    September 14, 2009 at 5:13 pm
    Boris says it’s an issue with final cut and apple is working on it.
  • Ghedina Stefan
    September 25, 2009 at 7:11 am
    Hi!
    I’ve got the same interlacing problem with the Boris Title Crawl in Final cut 7. I end up making my crawls in Premiere and export it to FCP.
    Has anybody got news from apple about this problem?
    Or are there any easier workarounds?
    Thanks for your answers.
    Stefan Ghedina
    Cutter and Producer
  • Rajesh Barnabas
    February 7, 2010 at 9:51 am
    take rasertization off on the FC controls. that will do the trick with this borris scrolling text. also color is good rather than just white on black text. that creates too much contrast espeecially if the text is thin.
