Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 beachballs when copying files in finder ?
  • FCP 7 beachballs when copying files in finder ?
    Posted by Neil Goodman on June 27, 2012 at 4:29 pm
    this is new. anytime i do some copying in finder, FCP beachballs until the file transfer is done. This happens even when using drives FCP doesnt have access to.
    never seen this behavior before but its pretty annoying.
    Anyone else see this?
    Neil Goodman: Editor of New Media Production – NBC/Universal
    Neil Goodman replied 14 years, 3 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    June 27, 2012 at 5:16 pm
    Post more about your setup there. What drives does FCP have no access to that you do on the same mac?
    You’re working on a LAN or are the media files locally stored? or? Also what codecs are you editing from and to?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Neil Goodman
    June 27, 2012 at 6:54 pm
    im not on a SAN or shared storage setup. All local drives either esata or firewire 800 or internal.
    working at any framerate although most everything here is XDCAM HD 422 60i.
    Final cut has access to all the drives, but even when copying files from drives that FCP doesnt need to access,ie no files from that drive are in the prject and not set for scrath disk use, it still beach balls.
  • Neil Goodman
    June 27, 2012 at 6:55 pm
    and if it helps Meida Composer 6, PPr5.5 and After Effects dont show this behavior. Just FCP 7
