Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 & AVC Intra
FCP 7 & AVC Intra
Posted by Michael Williams on September 2, 2009 at 6:01 pmA client is looking to upgrade to FCP 7 because he wants to take advantage of AVC Intra. anybody doing this now? Would love to hear if the group thinks this is a good idea.
mike
Michael V. Williams
producer/editor
http://www.vernonvision.comJeremy Garchow replied 17 years, 1 month ago 5 Members · 7 Replies -
Shane Ross
September 2, 2009 at 6:06 pmThe import option in LOG AND TRANSFER now has AVCIntra Native as an import option….so importing that is fast, and lighter than ProRes. BUT…you cannot have an AVCIntra Native sequence. Odd, but true. So you can import AVCI, but your sequence settings should be ProRes and you will be rendering to ProRes.
Or get the great tools from MXF4QT or Calibrated or Raylight and edit the MXF files natively, without the need to import.
Shane
Read my blog, Little Frog in High Def -
Jeremy Garchow
September 2, 2009 at 6:40 pmEverything that Shane says. MXF4mac has just released P2 Flow as well which is a hnady application for handling native MXF files in FCP with complete metadata.
We shoot a lot of AVC-I and the files go in to a ProRes HQ sequence (FCP default).
It works very well and the rt is fantastic.
Jeremy
Bruce Feagle
September 3, 2009 at 5:42 amHi guys,
What kind of RT performance could be expected with wrapped AVCI clips? What about rendering time?
Bruce Feagle
Jeremy Garchow
September 3, 2009 at 3:29 pm[Bruce Feagle] “What kind of RT performance could be expected with wrapped AVCI clips?”
The clips come in with a green bar over them and every clip eventually has to be rendered, but the rendering goes very fast. The rt is roughly the same as editing with ProRes or HQ.
Hector Silva
September 4, 2009 at 4:20 pmThe reason why it’s roughly the same speed of RT as ProRes is because it is ProRes.
Final Cut now knows how to play back the clips in the timeline, but any changes will be rendered out in ProRes since there is no way for Final Cut to write new AVC-I video, it’s just too intensive. So Apple’s claims of native AVC-Intra editing is kind of a half-truth. The footage is native, but transitions and other new elements are not.
Jeremy Garchow
September 4, 2009 at 4:23 pm[Hector Silva] “The reason why it’s roughly the same speed of RT as ProRes is because it is ProRes.
“No, it’s not. The clips that are being decoded are AVC-I, the are just not getting reencoded to AVC-I. So basically, you are playing a different codec within a ProRes timeline. So it’s not exactly ProRes (unless you choose to transcode to ProRes in log and transfer). If you put an AVC-I clip in a ProResHQ timeline with no transitions or effects, the render times are very fast.
[Hector Silva] “The footage is native, but transitions and other new elements are not. “
Correct.
