Activity › Forums › Apple Final Cut Pro Legacy › FCP 6.0.6 Crashes when viewing PNGs
  • FCP 6.0.6 Crashes when viewing PNGs
    Posted by Clayton Nygaard on January 12, 2010 at 8:02 pm
    One of the edit bays I support is crashing when the producer is previewing PNGs from the bin, arrowing through them. The crash reported generated leads me to believe it has to do with the ProRes422 codec somehow. Here’s the important info from the crash report:
    Process: Final Cut Pro [6562]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 6.0.6 (6.0.6)
    Build Info: FCPApp-905291121~12
    Code Type: X86 (Native)
    Parent Process: launchd [6482]
    Interval Since Last Report: 5349525 sec
    Crashes Since Last Report: 12
    Per-App Interval Since Last Report: 1014657 sec
    Per-App Crashes Since Last Report: 7
    Date/Time: 2010-01-12 09:26:20.104 -0500
    OS Version: Mac OS X 10.5.8 (9L31a)
    Report Version: 6
    Anonymous UUID: F0526D52-804D-4579-98AE-2C4A7415C395
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000044035259
    Crashed Thread: 25
    Thread 25 Crashed:
    0 com.apple.AppleProRes422 0x0c47ddd5 0xc459000 + 150997
    1 com.apple.AppleProRes422 0x0c47dbc0 0xc459000 + 150464
    2 com.apple.AppleProRes422 0x0c463c5c IcpDecompressorComponentDispatch + 29000
    3 com.apple.AppleProRes422 0x0c465503 IcpDecompressorComponentDispatch + 35311
    4 com.apple.AppleProRes422 0x0c47acb9 0xc459000 + 138425
    5 libSystem.B.dylib 0x96621155 _pthread_start + 321
    I am running on Generation 1 Mac Pros (2 3ghz dual core xeons, with 4GB of RAM and an Nvidia 8800GT) with 10.5.8. Any ideas?
    Manu Zapardiel replied 16 years, 6 months ago 3 Members · 3 Replies
  • David Bogie
    January 13, 2010 at 4:54 pm
    None of those PNGs are set to CMYK are they?
    I’ve recently had a terrible issue with FCP crashing out of nowhere. Turned out I had to uninstall and delete Qmaster to get back to work. No idea why or what happened and I’m NOT SAYING you need to do that. I am saying that chasing down FCP crashes is largely a frustrating waste of time.
    bogiesan
  • Clayton Nygaard
    January 13, 2010 at 5:00 pm
    Nope, they are all RGB, that’s the first thing I had the producer check in PS when I was notified of the problem.
    They are high-resolution images however. What I am thinking is happening is FCP is decompressing each PNG file and because they are large it takes a few seconds, and because he is arrowing through them so quickly, FCP decides it’s too much and just dies. Would this be a valid thought? I am going to find out where they are located on our XSAN and try it out on my test machine to see if I can reproduce the results.
  • Manu Zapardiel
    March 25, 2010 at 10:21 pm
    Hi!
    my fcp always crashes charging any bin with viewer in “large icons”.
    Did you find any solution!!!
    please i need help!
