Activity Forums Apple Final Cut Pro Legacy FCP 6.0.5-out of sync after capture
  • FCP 6.0.5-out of sync after capture
    Posted by Tommaso Cicognani on February 5, 2009 at 9:05 am
    hi all, I got a problem when I capture (with capture now) a mini dv from my sony hvr-m15j deck.
    The file fcp creates is out of sync or,better,some parts of it are out of sync. This happens only when I capture an entire cassette.
    How can I sove it?
    thanks
    Tommaso Ci
    Christopher Wright replied 17 years, 7 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    February 5, 2009 at 2:34 pm
    Log and capture. Don’t use capture now.
  • Tommaso Cicognani
    February 5, 2009 at 2:44 pm
    I made a test:
    I try to capture it also with premiere pro cs4 but the problem still persists.
    Is is possible that the problem is in the cassette (minidv),in the deck or a drop frame that shift me audio and video.
    I got the same problem 2 month ago…
  • Christopher Wright
    February 6, 2009 at 7:53 pm
    I have indeed found that there are some codec problems that are causing sync issues in FCP 6.05 when working with DV footage. I was able to use PPro CS4 for the projects with the miniDV footage with no issues at all however.
    Dual 2.5 G5, IO, Kona LH, IO, Medea Raid, UL4D, NVidia 6800, 4Gig RAM
    Octocore 8 GB Ram, Radeon card, MBP, MXO
    Windows Vista Adobe Studio CS4, Vegas 8.0, Lightwave 9.3, Sound Forge 9, Acid Pro 7, Continuum 5, Boris Red 4, Combustion 2008, Sapphire Effects
