Activity Forums Apple Final Cut Pro Legacy FCP 6.0.5 losing ‘REEL’ info on clips
  • FCP 6.0.5 losing ‘REEL’ info on clips
    Posted by Sam Mangan on May 26, 2009 at 10:17 am
    Hello all.
    I have an issue in 6.0.5 of Final Cut Pro that I’ve never come across before. I have an editor working on 6.0.5 on OSX 10.4.11. He is working in an AJA KONA 3 Pro Res 422 HQ 1080 project.
    Basically they are capturing in material from archive sources (VHS / DVD) and upscaling via the AJA. The editor is entering a reel name in and then using the ‘capture no’ function as these formats have no timecode.
    The footage captures in fine. However, whenever he renames a clip from say ‘cipname12’ to ‘vietnam aerial footage 12’ the ‘REEL’ column becomes blank. So it’s losing all relation to this info. This has only just been spotted and obviously is already causing problem further down the line as this info will be needed to relate back to when archive sources need ordering up for replacement.
    I have told the editor to replicate the ‘reel’ name in his ‘description’ field as well as then at least we can get this info from clips by ‘reveal in finder’. But currently he has only been entering info into the ‘REEL’ column.
    Does anyone know how to stop this from happening or has encountered this before? I have taken a copy of his project and tested it on my system which is 6.0.5 as well. The only difference is that I’m on 10.5.6.
    Any help would be most appreciated.
    Regards,
    Sam Mangan
    Sam Mangan replied 17 years, 3 months ago 2 Members · 2 Replies
  • Richard Sanchez
    May 26, 2009 at 2:05 pm
    I’ve seen similar issue before, though not this one specifically. However, I would try trashing preferences.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Sam Mangan
    June 1, 2009 at 10:59 am
    Just to update, I have now upgraded this system to 10.5.7 and the issue is still present.
    I have tried to resolve the issue but have still not had any luck.
    One thing that is really causing me headaches is that reel information disappears from the browser window when clips are re-named, not just captured. There is no reason this should be happening as this info should be stored in the XML of the project.
    Any help would really be appreciated.
    Sam
