Activity › Forums › Apple Final Cut Pro Legacy › FCP 6.0.5 constantly crashing
  • FCP 6.0.5 constantly crashing
    Posted by Mike Halper on May 8, 2009 at 11:02 pm
    I have a 78 minute film I’ve edited and am now doing color correction. Media is all DVCProHD from and HVX200. I’m doing color correction using Magic Bullet Looks 1.2. FCP 6.0.5 constantly crashes when I move the playhead to different clips on the timeline. It doesn’t matter if the clips have any filters on them or not, so I’m not sure it’s related to Looks or not. It also eventually crashes if I try playing the timeline in Unlimited RT. I haven’t tried rendering the entire sequence yet, but rendering a clip here and there has worked fine.
    I have a Blackmagic Design Multibridge Pro 2 with the latest 7.1.2 drivers. Had the same issue with the 7.0 drivers. I didn’t seem to have this issue with the 6.8.7 drivers before the 7.0 came out, but I never really tried using Looks before this. I have thought about going back to the old drivers.
    The FCP crash report is below. Sorry for pasting the entire report, but I don’t know what to really look at to determine the cause. Thanks for the help.
    ————- Start Crash Report —————-
    Process: Final Cut Pro [266]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 6.0.5 (6.0.5)
    Build Info: FCPApp-810171515~24
    Code Type: X86 (Native)
    Parent Process: launchd [182]
    Date/Time: 2009-05-08 15:47:22.498 -0700
    OS Version: Mac OS X 10.5.6 (9G55)
    Report Version: 6
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000009f3a2da
    Crashed Thread: 0
    Thread 0 Crashed:
    0 libSystem.B.dylib 0xffff07c7 __memcpy + 39 (cpu_capabilities.h:246)
    1 libSystem.B.dylib 0xffff1222 __longcopy + 34 (cpu_capabilities.h:249)
    2 libSystem.B.dylib 0xffff086e __memcpy + 206 (cpu_capabilities.h:246)
    3 libGLImage.dylib 0x91eecb96 glgProcessPixelsWithProcessor + 342
    4 GLEngine 0x09f26eb8 gleTextureImagePut + 1752
    5 GLEngine 0x09f25482 glTexImage2D_Exec + 706
    6 com.apple.QuartzComposer 0x91d73823 -[QCImageTextureBuffer uploadTextureWithBaseAddress:releaseCallback:releaseInfo:bytesPerRow:] + 878
    7 com.apple.QuartzComposer 0x91d7307d -[QCImageManager(Internal) createTextureBufferFromPixelBuffer:target:bounds:options:] + 1761
    8 com.apple.QuartzComposer 0x91d72278 -[QCImageManager createTextureBufferFromImageBuffer:target:sourceBounds:options:] + 2683
    9 com.apple.QuartzComposer 0x91e882af -[QCOpenGLContext(FCPImageExtensions) textureFromImage:outName:outFlipped:] + 490
    10 …uartzComposer.FxPlugWrapper 0x0ff3edd0 FxImageInfoFromQCImage + 1714
    11 …uartzComposer.FxPlugWrapper 0x0ff3e652 QCImageBytesPerPixel + 736
    12 …uartzComposer.FxPlugWrapper 0x0ff39a11 0xff33000 + 27153
    13 com.apple.QuartzComposer 0x91d3dfa0 -[QCPatch(Private) _execute:arguments:] + 1231
    14 com.apple.QuartzComposer 0x91d3c614 -[QCContext renderPatch:time:arguments:] + 650
    15 com.apple.QuartzComposer 0x91d3c366 -[QCGraphicsContext renderPatch:time:arguments:] + 91
    16 com.apple.QuartzComposer 0x91d3b26b -[QCOpenGLContext renderPatch:time:arguments:] + 334
    17 com.apple.QuartzComposer 0x91d3b10a -[QCPatch(Runtime) render:arguments:] + 92
    18 com.apple.FinalCutPro 0x004fb915 RenderQCPatch + 1677
    19 com.apple.FinalCutPro 0x004f8657 FCPQCMainEntry(long, long, KGDictInt*, void*) + 9609
    20 com.apple.FinalCutPro 0x002d3648 pKGRunTransition(KGDictInt*) + 2064
    21 com.apple.FinalCutPro 0x0023e6cb GetFilterFrame(KGDictInt*, KGClipItemType, long, unsigned char, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 3717
    22 com.apple.FinalCutPro 0x0023eee7 DoVImageMotion(KGDictInt*, KGClipItemType, KGMotionPointInstance*, BufferInfoRec*, KGCanvasRec*, KGRect*, int, KGFieldType*, unsigned char, KGRect, KGRect, KGRect, unsigned char, renderStackInfo*, WhenRec*, double, unsigned char*, KGFloatPt*, KGFloatPt*, KGRect*, CGAffineTransform*, KGAffineTransformQuality, unsigned char*) + 179
    23 com.apple.FinalCutPro 0x00241897 GetMotionFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 6223
    24 com.apple.FinalCutPro 0x00243c71 GetBlurFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 2641
    25 com.apple.FinalCutPro 0x002451be GetTrackItemFrame(KGDictInt*, TrackInfoRec*, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*) + 5438
    26 com.apple.FinalCutPro 0x0023afc9 CompositeLoop(KGDictInt*, WhenRec*, KGCanvasRec*, KGRect*, BufferInfoRec*, renderStackInfo*, unsigned char*, TrackItemAtTimeCache*) + 1497
    27 com.apple.FinalCutPro 0x00246b34 pKGGetClipVideoWithAlpha(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, AlphaType*, unsigned long long) + 5288
    28 com.apple.FinalCutPro 0x00239ed9 pKGGetClipVideoWithAlphaMulticlip(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, AlphaType*, unsigned long long) + 263
    29 com.apple.FinalCutPro 0x004477c6 GetVideoFromRenderEngine(XXGlobals*, Output*) + 812
    30 com.apple.FinalCutPro 0x0044b256 DecodePipeTree(XXGlobals*, Output*) + 184
    31 com.apple.FinalCutPro 0x00417939 FCPMediaHandler::RenderFrames(long long, bool) + 4049
    32 com.apple.FinalCutPro 0x00417f54 FCPMediaHandler::Idle(long, long, long*, TimeRecord*) + 582
    33 com.apple.FinalCutPro 0x00418f49 FCPMHIdle(FCPMediaHandler*, long, long, long*, TimeRecord*) + 45
    34 …ple.CoreServices.CarbonCore 0x90d3709f CallComponentFunctionCommon + 1403
    35 com.apple.FinalCutPro 0x004119c3 FCPMHDispatch(ComponentParameters*, char**) + 55
    36 …ple.CoreServices.CarbonCore 0x90d36a05 CallComponentDispatch + 29
    37 …ickTimeComponents.component 0x935b6d76 MediaIdle + 61
    38 …ickTimeComponents.component 0x92e9bd06 doGenericIdle + 2091
    39 …ickTimeComponents.component 0x92e9d466 GenericMoviesTask + 337
    40 …ple.CoreServices.CarbonCore 0x90d3709f CallComponentFunctionCommon + 1403
    41 …ickTimeComponents.component 0x92e9ce53 GenericComponentDispatch + 170
    42 com.apple.FinalCutPro 0x004119df FCPMHDispatch(ComponentParameters*, char**) + 83
    43 …ple.CoreServices.CarbonCore 0x90d36a05 CallComponentDispatch + 29
    44 com.apple.QuickTime 0x96b5c003 MediaMoviesTask + 61
    45 com.apple.QuickTime 0x96ab7f54 TaskMovie_priv + 4811
    46 com.apple.QuickTime 0x96b98a1f MoviesTask_priv + 100
    47 com.apple.FinalCutPro 0x001b06b8 DoMoviesTask(KGPlayerRec*) + 2446
    48 com.apple.FinalCutPro 0x001c282d DisplayMovie(KGPlayerRec*) + 2235
    49 com.apple.FinalCutPro 0x001c7444 pKGPlayerGoto(KGPlayerRec*, double, long, unsigned char) + 512
    50 com.apple.FinalCutPro 0x001b0edb PlayerNotify(long, long, KGDictInt*, void*) + 143
    51 com.apple.FinalCutPro 0x0010f4fa DispatchNotificationsHelp(void**, KGDictInt*, long, long, unsigned char) + 164
    52 com.apple.FinalCutPro 0x0010f7e4 DispatchNotifications + 260
    53 com.apple.FinalCutPro 0x0001e931 HashInsertFull(HashDict*, char*, long, unsigned char, void*, KGTypeValueContainer*, void**, unsigned char, KGDictNotifyHolder**, KGDictUndoMethod, long, unsigned char, unsigned long) + 1055
    54 com.apple.FinalCutPro 0x0002006b DispatchHashDict(KGDictSelector, KGDictInt*, KGDictParams*) + 227
    55 com.apple.FinalCutPro 0x00110500 pKGDictPut1(KGDictInt*, void*, long, char*) + 90
    56 com.apple.FinalCutPro 0x001029ae pKGRulerMessage(long, long, KGDictInt*, KGViewRecord*) + 6650
    57 com.apple.FinalCutPro 0x00292c45 PPassMouseEvent(KGPanelRecord*, KGDictInt*, long) + 1483
    58 com.apple.FinalCutPro 0x0029be99 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 75
    59 com.apple.FinalCutPro 0x0024b803 ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 109
    60 com.apple.FinalCutPro 0x0024cce1 TimelineMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 101
    61 com.apple.FinalCutPro 0x002923fd pKGPanelWindowProc(long, long, KGDictInt*, void*) + 53
    62 com.apple.FinalCutPro 0x002a71ef pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 93
    63 com.apple.FinalCutPro 0x0015018e HandleMouseDown(OpaqueEventRef*) + 1260
    64 com.apple.FinalCutPro 0x00151110 DoEvent(OpaqueEventRef*, KGDictInt*) + 686
    65 com.apple.FinalCutPro 0x004000fd Events(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 69
    66 com.apple.HIToolbox 0x9030c143 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
    67 com.apple.HIToolbox 0x9030b57d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
    68 com.apple.HIToolbox 0x90327ed2 SendEventToEventTarget + 52
    69 com.apple.HIToolbox 0x9033a0a8 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1208
    70 com.apple.HIToolbox 0x9030c4fc DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2134
    71 com.apple.HIToolbox 0x9030b57d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
    72 com.apple.HIToolbox 0x90327ed2 SendEventToEventTarget + 52
    73 com.apple.HIToolbox 0x90394b80 ToolboxEventDispatcher + 86
    74 com.apple.HIToolbox 0x903913da RunApplicationEventLoop + 222
    75 com.apple.FinalCutPro 0x0014cece KGMainEvent(void*) + 46
    76 com.apple.FinalCutPro 0x002aae53 main + 59
    77 com.apple.FinalCutPro 0x00003122 _start + 216
    78 com.apple.FinalCutPro 0x00003049 start + 41
    Thread 1:
    0 libSystem.B.dylib 0x94b786f2 select$DARWIN_EXTSN + 10
    1 libSystem.B.dylib 0x94b5a095 _pthread_start + 321
    2 libSystem.B.dylib 0x94b59f52 thread_start + 34
    Thread 2:
    0 libSystem.B.dylib 0x94b303ae __semwait_signal + 10
    1 libSystem.B.dylib 0x94b5ad0d pthread_cond_wait$UNIX2003 + 73
    2 libGLProgrammability.dylib 0x9375eb32 glvmDoWork + 162
    3 libSystem.B.dylib 0x94b5a095 _pthread_start + 321
    4 libSystem.B.dylib 0x94b59f52 thread_start + 34
    Thread 3:
    0 libSystem.B.dylib 0x94b2920e semaphore_wait_signal_trap + 10
    1 libSystem.B.dylib 0x94b5b206 _pthread_cond_wait + 1267
    2 libSystem.B.dylib 0x94ba0539 pthread_cond_wait + 48
    3 com.apple.FinalCutPro 0x004292ad Synchronizable::Wait() + 47
    4 com.apple.FinalCutPro 0x004152e8 DisplayQueue::Run() + 702
    5 com.apple.FinalCutPro 0x00453544 Thread::RunHelper(void*) + 20
    6 libSystem.B.dylib 0x94b5a095 _pthread_start + 321
    7 libSystem.B.dylib 0x94b59f52 thread_start + 34
    Thread 4:
    0 libSystem.B.dylib 0x94b292e6 mach_wait_until + 10
    1 …ple.CoreServices.CarbonCore 0x90d65933 MPDelayUntil + 39
    2 …ple.CoreServices.CarbonCore 0x90d657c7 Delay + 104
    3 …dgiantsoftware.deartifacter 0x0d59497a RGS::SerialServer::ThreadProcess() + 54
    4 …ple.CoreServices.CarbonCore 0x90d4d0a3 PrivateMPEntryPoint + 56
    5 libSystem.B.dylib 0x94b5a095 _pthread_start + 321
    6 libSystem.B.dylib 0x94b59f52 thread_start + 34
    Thread 5:
    4 com.apple.FinalCutPro 0x004cc3e3 WorkUnitPerformer::Run() + 55
    Thread 6:
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    0 libSystem.B.dylib 0x94b291c6 mach_msg_trap + 10
    1 libSystem.B.dylib 0x94b309bc mach_msg + 72
    2 com.apple.CoreFoundation 0x9023d0ae CFRunLoopRunSpecific + 1790
    3 com.apple.CoreFoundation 0x9023dd34 CFRunLoopRun + 84
    4 com.apple.DVCPROHDMuxer 0x2913e0fb AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 297
    Thread 13:
    3 com.apple.CoreFoundation 0x9023dcd8 CFRunLoopRunInMode + 88
    4 com.apple.audio.CoreAudio 0x946825dc HALRunLoop::OwnThread(void*) + 160
    5 com.apple.audio.CoreAudio 0x94682464 CAPThread::Entry(CAPThread*) + 96
    Thread 14:
    4 ….CoreMediaIOServicesPrivate 0x9066bf88 MIO::DAL::RunLoop::OwnThread(void*) + 160
    5 ….CoreMediaIOServicesPrivate 0x9066e108 CAPThread::Entry(CAPThread*) + 96
    Thread 15:
    0 libSystem.B.dylib 0x94b29226 semaphore_timedwait_signal_trap + 10
    1 libSystem.B.dylib 0x94b5b1ef _pthread_cond_wait + 1244
    2 libSystem.B.dylib 0x94b5ca73 pthread_cond_timedwait_relative_np + 47
    3 …ple.CoreServices.CarbonCore 0x90d2ddd2 TSWaitOnConditionTimedRelative + 246
    4 …ple.CoreServices.CarbonCore 0x90d2dbb2 TSWaitOnSemaphoreCommon + 422
    5 …ickTimeComponents.component 0x92e2dbee ReadSchedulerThreadEntryPoint + 4724
    Thread 16:
    2 com.apple.vImage 0x944dc4ef vImageQueue_DequeueJob + 111
    3 com.apple.vImage 0x944dc7bc vImageWorkerThreadFunc + 124
    4 libSystem.B.dylib 0x94b5a095 _pthread_start + 321
    5 libSystem.B.dylib 0x94b59f52 thread_start + 34
    Thread 17:
    Thread 18:
    Thread 19:
    Thread 20:
    Thread 21:
    Thread 22:
    Thread 23:
    4 com.apple.FinalCutPro 0x0008f6bf SyncMetaDataTask::GetNextEvent() + 81
    5 com.apple.FinalCutPro 0x00090e5f SyncMetaDataTask::Run() + 39
    6 com.apple.FinalCutPro 0x00453544 Thread::RunHelper(void*) + 20
    7 libSystem.B.dylib 0x94b5a095 _pthread_start + 321
    8 libSystem.B.dylib 0x94b59f52 thread_start + 34
    Thread 24:
    5 …ple.CoreServices.CarbonCore 0x90d56220 AIOFileThread(void*) + 1056
    Thread 25:
    0 libSystem.B.dylib 0x94b2921a semaphore_timedwait_trap + 10
    1 …ple.CoreServices.CarbonCore 0x90d6049b MPWaitOnSemaphore + 125
    2 com.apple.DVCPROHDCodec 0x0ccd998d 0xccd8000 + 6541
    3 …ple.CoreServices.CarbonCore 0x90d4d0a3 PrivateMPEntryPoint + 56
    Thread 26:
    Thread 27:
    Thread 28:
    Thread 29:
    Thread 30:
    Thread 31:
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x020100ff ebx: 0x00000026 ecx: 0x00000009 edx: 0x00000026
    edi: 0x09f3a2da esi: 0xf737d484 ebp: 0xbfffaa8c esp: 0xbfffaa84
    ss: 0x0000001f efl: 0x00010286 eip: 0xffff07c7 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    cr2: 0x09f3a2da
    Binary Images:
    0x1000 – 0x75cfe8 com.apple.FinalCutPro 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    0xb23000 – 0xb26fe0 +KGCore ??? (???) /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
    0xb2d000 – 0xb2dffc com.apple.iokit.dvcomponentglue 1.9.5 (1.9.5) <0759a2500bb678c4e6fc1c4a90d17e03> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0xb32000 – 0xb41ff7 com.apple.AERegistration 1.2 (72) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0xb53000 – 0xb5aff3 com.apple.AEProfiling 1.2 (18) /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0xb62000 – 0xccdfeb com.apple.prokit 4.5 (722) <372314d5b0a6b68af0ba352d0a910e1a> /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    0xdae000 – 0xddeffb com.apple.AVCVideoServices 1.0 (38) /Applications/Final Cut Pro.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
    0xe00000 – 0xe74ffb com.apple.ProFX 1.2.3 (1.2.3) /Library/Frameworks/ProFX.framework/Versions/A/ProFX
    0xe9f000 – 0xf97fe0 com.apple.DiskImagesFramework 10.5.4 (195.2.2) <62a6764ff62868031f882857791ff1d6> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0xffd000 – 0x1053fff com.apple.proapps.MIO 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
    0x108f000 – 0x1099fee com.apple.finalcutstudio.prometadatasupport 0.5 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
    0x10a3000 – 0x10d9fff com.apple.MediaKit 9.1 (401) <36149a69962ed3101199093a6220ef74> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x10ea000 – 0x11b3ff5 com.apple.DiscRecording 4.0.3 (4030.4.3) /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x121e000 – 0x1249ffb libcurl.4.dylib ??? (???) <54ada27deb3b4ff7043d8836264eca0d> /usr/lib/libcurl.4.dylib
    0x1253000 – 0x1285fff com.apple.FWAVCPrivate 1.0 (43) /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
    0x1500000 – 0x153ffff com.apple.vmutils 4.1 (104) <2fcd53ce313bb6050bfaf0ac6c1b5ead> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
    0x45ea000 – 0x45f2ff7 com.apple.proapps.mrcheckpro 1.4 (204) /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
    0x489e000 – 0x48baff7 GLRendererFloat ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x49e2000 – 0x49e6ff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
    0x49eb000 – 0x49f0fff com.apple.FinalCutPro.Plugins.Cache Manager 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
    0x49f5000 – 0x49f8ffc com.apple.FinalCutPro.Plugins.FinalTouchExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
    0x9c86000 – 0x9e7efff com.apple.RawCamera.bundle 2.0.13 (435) <083354ccec68bf7c9fc99523a5838f92> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x9f11000 – 0xa094fe3 GLEngine ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0xa0c2000 – 0xa36cfe9 com.apple.ATIRadeonX1000GLDriver 1.5.36 (5.3.6) <3f9984c88184d39af0ed1e486ab4616a> /System/Library/Extensions/ATIRadeonX1000GLDriver.bundle/Contents/MacOS/ATIRadeonX1000GLDriver
    0xb3cc000 – 0xb3e3ff7 com.apple.FinalCutPro.Plugins.AudioMixer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
    0xb3f2000 – 0xb3fafff com.apple.FinalCutPro.Plugins.Effect Builder 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
    0xb500000 – 0xb52bfe7 com.apple.FinalCutPro.Plugins.AfterEffects 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
    0xb535000 – 0xb552ff7 com.apple.audio.midi.CoreMIDI 1.6.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0xb56a000 – 0xb57efcf com.apple.proapps.ControlSurfaceSupport 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
    0xb594000 – 0xb5b2fe3 libexpat.1.dylib ??? (???) /usr/lib/libexpat.1.dylib
    0xb5ba000 – 0xb673fea com.apple.FinalCutPro.Plugins.Browser 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
    0xb68e000 – 0xb6a4fff com.apple.FinalCutPro.CinemaTools 4.0.1 (4.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
    0xb6b0000 – 0xb6bbff5 com.apple.FinalCutPro.Plugins.CTHelper 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
    0xb6c3000 – 0xb6e7ffb com.apple.FinalCutPro.Plugins.EditTape 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
    0xb6f7000 – 0xb73cfeb com.apple.FinalCutPro.Plugins.EDL Export 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
    0xb752000 – 0xb75dff2 com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
    0xb766000 – 0xb79aff6 com.apple.FinalCutPro.Plugins.FCS Engine 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
    0xb7a5000 – 0xb7b6fff com.apple.FinalCutPro.Plugins.FilterCustomEd 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
    0xb7bc000 – 0xb7d1ff3 com.apple.FinalCutPro.Plugins.FilterViewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
    0xb7d7000 – 0xb7f5fc3 com.apple.FinalCutPro.Plugins.Flash 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
    0xb806000 – 0xb813ff3 com.apple.FinalCutPro.Plugins.GenViewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
    0xb819000 – 0xb81dfff com.apple.FinalCutPro.Plugins.LayerFileReader 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
    0xb822000 – 0xb86dffb com.apple.FinalCutPro.Plugins.Media Manager 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
    0xb87a000 – 0xb88d06e com.apple.FinalCutPro.Plugins.MolokiniSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
    0xb89b000 – 0xb8affff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
    0xb8bc000 – 0xb8d0ff3 com.apple.FinalCutPro.Plugins.Motion Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
    0xb8d6000 – 0xb8f2ff7 com.apple.FinalCutPro.Plugins.Movie Analyzer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
    0xb902000 – 0xb918feb com.apple.FinalCutPro.Plugins.Movie Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0xb924000 – 0xb928fff com.apple.FinalCutPro.Plugins.NuggetExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
    0xb92d000 – 0xb9e5fc7 com.apple.FinalCutPro.Plugins.OMF Audio Export 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
    0xba04000 – 0xba0dff7 com.apple.FinalCutPro.Plugins.Perf Analyzer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
    0xba12000 – 0xba28ff9 com.apple.FinalCutPro.Plugins.ProAppsIntegration 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
    0xba38000 – 0xba45ff3 com.apple.FinalCutPro.Plugins.Pulldown Support 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
    0xba4e000 – 0xba8dff7 com.apple.FinalCutPro.Plugins.QTM Reader 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
    0xba9a000 – 0xbaa2fef com.apple.FinalCutPro.Plugins.QuickView 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
    0xbaa7000 – 0xbab7ff0 com.apple.FinalCutPro.Plugins.Relink Media 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
    0xbabe000 – 0xbabffff com.apple.FinalCutPro.Plugins.Text Window 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
    0xbac4000 – 0xbb3fff4 com.apple.FinalCutPro.Plugins.Timeline Editor 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
    0xbb4a000 – 0xbb51fef com.apple.FinalCutPro.Plugins.Transcoder 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
    0xbb57000 – 0xbb69ffb com.apple.FinalCutPro.Plugins.Transition Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
    0xbb6f000 – 0xbb84ff3 com.apple.FinalCutPro.Plugins.Trimming 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
    0xbb8a000 – 0xbb90ff7 com.apple.FinalCutPro.Plugins.VDUSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
    0xbb96000 – 0xbb97fff com.apple.FinalCutPro.Plugins.Vector Accelerator 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
    0xbb9c000 – 0xbbadffb com.apple.FinalCutPro.Plugins.VideoLog 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
    0xbbb2000 – 0xbbcafeb com.apple.FinalCutPro.Plugins.VoiceOver 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
    0xbbd1000 – 0xbc35ffb com.apple.FinalCutPro.Plugins.XML Support 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
    0xbf40000 – 0xbf40ffd libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
    0xc35e000 – 0xc370fd9 com.apple.FCP Uncompressed 422.component 1.5 (1.5) /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0xc376000 – 0xc390fc3 com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0xc3ef000 – 0xc3f2fef com.apple.LiveType.component 2.1.3 (2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0xc3f7000 – 0xc45cfde com.apple.LiveType.framework 2.1.3 (2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
    0xc47c000 – 0xc4eefff +com.DivXInc.DivXDecoder 6.4.0 (6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0xc4fc000 – 0xc542fc3 com.apple.motion.component 1.0 (1.0) <77973a134e79426f853f2318e52a2207> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    0xc548000 – 0xc54b02f +Motion ??? (???) /Library/Frameworks/Motion.framework/Versions/A/Motion
    0xc550000 – 0xc565fcf com.apple.fcp.DVOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
    0xc718000 – 0xc7d5feb +com.blackmagic-design.BlackmagicCodec ??? (7.1.2) <7af81460d72982fdb0b01ba489bbdaf4> /Library/QuickTime/Blackmagic Codec.component/Contents/MacOS/Blackmagic Codec
    0xc812000 – 0xc84cfff com.apple.AppleProRes422 1.0.2 (46) /Library/QuickTime/AppleProRes422.component/Contents/MacOS/AppleProRes422
    0xc898000 – 0xcc6dfe5 QuickTimeH264.scalar ??? (???) /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
    0xccd8000 – 0xcd1cfe7 com.apple.DVCPROHDCodec 1.4 (231) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0xcd31000 – 0xcd77fef com.apple.viceroy.codec 32.1 (32.1) /System/Library/Components/VCH263Codec.component/VCH263Codec
    0xcd80000 – 0xce23fd3 com.apple.AppleHDVCodec 1.4.1 (222) <68abd695e9904f5f9074d2c4ae440637> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0xce41000 – 0xce8dfe3 com.apple.AppleVAFramework 4.1.14 (4.1.14) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0xce96000 – 0xceb6ff3 com.apple.IMXCodec 1.3.1 (147) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0xcece000 – 0xcee7ff3 com.apple.applepixletvideo 1.2.18 (1.2d18) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0xceec000 – 0xcf27fff com.apple.QuickTimeFireWireDV.component 7.6 (1290) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0xd004000 – 0xd009fff com.apple.finalcutpro.dvcprohdfrcplugin 1.2.0 (16) /Applications/Final Cut Pro.app/Contents/PlugIns/DVCPROHD Frame Rate Converter.bundle/Contents/MacOS/DVCPROHD Frame Rate Converter
    0xd0d6000 – 0xd124fe3 com.apple.soundtrackpro.integration 2.0.2 () <3a8f3a1f839f4d6998bb14b5570902ab> /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
    0xd13f000 – 0xd176fe7 com.apple.motion.MotionBundle 3.0.2 (3.0.2) /Library/Application Support/ProApps/Bundles/Motion.bundle/Contents/MacOS/Motion
    0xd57d000 – 0xd5aafc4 +com.redgiantsoftware.deartifacter ??? (2.1.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Deartifacter.bundle/Contents/MacOS/Deartifacter
    0xd5d3000 – 0xd642fcf +com.redgiantsoftware.looksuite ??? (2.1.1) /Library/Application Support/Final Cut Pro System Support/Plugins/LookSuite.bundle/Contents/MacOS/LookSuite
    0xdd00000 – 0xdd18fdf +com.redgiantsoftware.MisFire.Basic.Scratches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Basic Scratches.bundle/Contents/MacOS/MisFire Basic Scratches
    0xe8b2000 – 0xe8d0fd0 +com.redgiantsoftware.MisFire.Deep.Scratches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Deep Scratches.bundle/Contents/MacOS/MisFire Deep Scratches
    0xff33000 – 0xff43fff com.apple.QuartzComposer.FxPlugWrapper 1.2.3 (1.2.3) /Library/Application Support/ProApps/Internal Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
    0xff4e000 – 0xff5afff com.apple.PluginManager 1.7.3 (34) /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
    0xff66000 – 0xff76fff com.apple.fxplugframework 1.2.3 (1.2.3) /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
    0xffd7000 – 0xffe0fdf com.apple.QuartzComposer.QCMotionPatch 1.0 (1.0) <7b4d4ca7a74444c7a7a61deff2c3aa75> /Library/Application Support/ProApps/Internal Plug-Ins/ProFX/QCMotionPatch.plugin/Contents/MacOS/QCMotionPatch
    0x10000000 – 0x1005efef com.apple.proapps.AudioMixEngine 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x200a3000 – 0x200bbfc4 +com.redgiantsoftware.MisFire.Displace ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Displacement.bundle/Contents/MacOS/MisFire Displacement
    0x20c55000 – 0x20c70fca +com.redgiantsoftware.MisFire.Dust ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Dust.bundle/Contents/MacOS/MisFire Dust
    0x2181c000 – 0x21833ff4 +com.redgiantsoftware.MisFire.Fading ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Fading.bundle/Contents/MacOS/MisFire Fading
    0x223cc000 – 0x223e3fd8 +com.redgiantsoftware.MisFire.Flicker ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Flicker.bundle/Contents/MacOS/MisFire Flicker
    0x22f7c000 – 0x22f93fdc +com.redgiantsoftware.MisFire.Funk ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Funk.bundle/Contents/MacOS/MisFire Funk
    0x23b2c000 – 0x23b47fc0 +com.redgiantsoftware.MisFire.Gate.Weave ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Gate Weave.bundle/Contents/MacOS/MisFire Gate Weave
    0x246f3000 – 0x24712fc8 +com.redgiantsoftware.MisFire.Grain ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Grain.bundle/Contents/MacOS/MisFire Grain
    0x252bf000 – 0x252dafc8 +com.redgiantsoftware.MisFire.MicroScratches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire MicroScratches.bundle/Contents/MacOS/MisFire MicroScratches
    0x25e86000 – 0x25e9dfd4 +com.redgiantsoftware.MisFire.Post.Contrast ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Post Contrast.bundle/Contents/MacOS/MisFire Post Contrast
    0x26a36000 – 0x26a51fd6 +com.redgiantsoftware.MisFire.Splotches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Splotches.bundle/Contents/MacOS/MisFire Splotches
    0x275fd000 – 0x27614fd4 +com.redgiantsoftware.MisFire.Vignette ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Vignette.bundle/Contents/MacOS/MisFire Vignette
    0x281ad000 – 0x281dafd7 +com.redgiantsoftware.MisFire ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire.bundle/Contents/MacOS/MisFire
    0x28d9c000 – 0x28da1fe3 com.apple.SmoothCamFxPlug 1.0.1 (1.0.1) /Library/Application Support/ProApps/Internal Plug-Ins/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
    0x28da8000 – 0x28da9fff com.apple.Helium 2.1.2 (2.1.2) /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
    0x28dad000 – 0x28de1fcf com.apple.Helium.HeliumRender 1.0.2 (1.0.2) /System/Library/PrivateFrameworks/Helium.framework/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
    0x28f00000 – 0x29032fe0 com.apple.motion.filters 3.0.2 (3.0.2) /Library/Application Support/ProApps/Internal Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
    0x29093000 – 0x29096fff com.apple.audio.AudioIPCPlugIn 1.0.5 (1.0.5) /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0x2909c000 – 0x290a1fff com.apple.audio.AppleHDAHALPlugIn 1.6.2 (1.6.2a37) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0x290a6000 – 0x290fcfd6 com.apple.DVCPROHDAudio 1.3 (1.3) /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0x2912c000 – 0x29176fec com.apple.DVCPROHDMuxer 1.3 (1.3) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0x29194000 – 0x2919fffe com.apple.fcp.TundraOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
    0x291ab000 – 0x291d4ffa com.apple.mio.DAL.AVC 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Resources/AVC.plugin/Contents/MacOS/AVC
    0x291f9000 – 0x29223fff com.apple.audio.SoundManager.Components 3.9.3 (3.9.3) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0x29229000 – 0x29235ff7 com.apple.DVCPROHDVideoOutput 1.3 (1.3) /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0x2923d000 – 0x29242ff7 com.apple.DesktopVideoOut 1.2.4 (1.2.4) /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0x29247000 – 0x29250fff com.apple.IOFWDVComponents 1.9.5 (1.9.5) <889959011cb23c11785c378264400284> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0x29278000 – 0x29279ffc com.apple.compressor.stomp 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Compressor
    0x29296000 – 0x292fefe3 +com.digitalanarchy.ReSizer2 2.2.3 (2.2.3) <1bf218a047b93be5476551306726644b> /Library/Plug-Ins/FxPlug/ReSizer.fxplug/Contents/MacOS/ReSizer
    0x2933f000 – 0x29340ffc com.apple.qmaster.swamp 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
    0x29d4b000 – 0x2a480fdf +com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
    0x2aebf000 – 0x2b5f1fc7 +com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
    0x2c02f000 – 0x2c75ffef +com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
    0x2d19c000 – 0x2d8d2ff7 +com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
    0x2e34e000 – 0x2e359fff com.apple.compressor.MediaServerAPI 3.0.5 (3.0.5) /Library/Frameworks/MediaServerAPI.framework/MediaServerAPI
    0x2e36d000 – 0x2e374fff com.apple.compressor.FilterUI 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
    0x2e399000 – 0x2e3a3ffc com.apple.qmaster.SwampUtil 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
    0x2e3b1000 – 0x2e3c7fe7 +com.redgiantsoftware.looks3fx 1.2 (1.2) /Library/Plug-Ins/FxPlug/Looks3.fxplug/Contents/MacOS/Looks3
    0x2e500000 – 0x2e564ff3 +com.redgiantsoftware.MBLooksRenderLib 1.2 (1.2) <728c832e405a081c0303f7a30ed617cf> /Library/Frameworks/LS3Renderer.framework/Versions/A/LS3Renderer
    0x2e588000 – 0x2e594fff com.apple.compressor.StompUtil 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
    0x2e5a3000 – 0x2e5c2fed com.apple.audio.CoreAudioKit 1.5 (1.5) <82f2e52c502db7f3b32349a54209a0fe> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
    0x2e60c000 – 0x2e615fff com.apple.qmaster.SwampService 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
    0x2e651000 – 0x2e6c1feb +com.redgiantsoftware.mbcc.slider 1.0 (1) <39ae3f5fb4113ddc983005297cb8b55b> /Library/Plug-Ins/FxPlug/MBCC_Slider.fxplug/Contents/MacOS/MBCC_Slider
    0x2e72d000 – 0x2e79dfeb +com.redgiantsoftware.mbcc 1.0 (1) /Library/Plug-Ins/FxPlug/MBCC.fxplug/Contents/MacOS/MBCC
    0x2f008000 – 0x2f016fff com.apple.qmaster.Status 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
    0x2f05c000 – 0x2f067fff com.apple.qmaster.RequestProcessing 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
    0x2f200000 – 0x2f21aff7 +com.redgiantsoftware.InstantHD 1.0 (1) /Library/Plug-Ins/FxPlug/InstantHD.fxplug/Contents/MacOS/InstantHD
    0x2f272000 – 0x2fc14fcf com.apple.ozone.framework 3.0.2 (3.0.2) /Applications/Motion.app/Contents/Frameworks/Ozone.framework/Ozone
    0x301ff000 – 0x30239fef +ProMath ??? (???) <92bc79aa652443aaab63994e4d88f004> /Users/mike_halper/Library/Frameworks/ProMath.framework/Versions/A/ProMath
    0x3024d000 – 0x302f8fce +ProCore ??? (???) /Users/mike_halper/Library/Frameworks/ProCore.framework/Versions/A/ProCore
    0x30344000 – 0x303c1fc3 +ProMedia ??? (???) /Users/mike_halper/Library/Frameworks/ProMedia.framework/Versions/A/ProMedia
    0x30443000 – 0x3045afef +ThirdPartyPlugins ??? (???) <9f2854877336439b8ef2169f820b1745> /Users/mike_halper/Library/Frameworks/ThirdPartyPlugins.framework/Versions/A/ThirdPartyPlugins
    0x30475000 – 0x304d1feb +ProGraphics ??? (???) <61f87c631750435983522e1859903eae> /Users/mike_halper/Library/Frameworks/ProGraphics.framework/Versions/A/ProGraphics
    0x305bf000 – 0x30728fe7 +Lithium ??? (???) <5ab1a031282844a5ae3f50f0493af478> /Users/mike_halper/Library/Frameworks/Lithium.framework/Versions/A/Lithium
    0x307f2000 – 0x309a7ff7 com.apple.motion.TextFramework 3.0.2 (3.0.2) <5724e41ced674788ab2041afc54e7e7b> /Applications/Motion.app/Contents/Frameworks/TextFramework.framework/TextFramework
    0x30a6e000 – 0x30abaff3 +Bloodhound ??? (???) <2afb0adb33be4a24aa3f4c6f6b057cb8> /Users/mike_halper/Library/Frameworks/Bloodhound.framework/Versions/A/Bloodhound
    0x30b01000 – 0x30b0cfff com.apple.motion.Text 3.0.2 (3.0.2) <416454d0e1c84517a28d656e6f14d26d> /Applications/Motion.app/Contents/PlugIns/Text.ozp/Contents/MacOS/Text
    0x30b24000 – 0x30ca6ff3 com.apple.motion.Behaviors 3.0.2 (3.0.2) /Applications/Motion.app/Contents/PlugIns/Behaviors.ozp/Contents/MacOS/Behaviors
    0x30d5c000 – 0x30ee0ff3 com.apple.motion.Particles 3.0.2 (3.0.2) <50a604442b174d84a881aa441cbf558a> /Applications/Motion.app/Contents/PlugIns/Particles.ozp/Contents/MacOS/Particles
    0x30f65000 – 0x30f6affb com.apple.fxmetaplug.ImageUnit 1.2.2 (1.2.2) /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
    0x30f72000 – 0x30f74ffb com.apple.Helium.HCache 2.1.2 (2.1.2) /System/Library/PrivateFrameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
    0x3108c000 – 0x3109dff7 com.apple.qmaster.ServiceControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
    0x310b7000 – 0x310c3ffe com.apple.qmaster.ClusterManager 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
    0x310d5000 – 0x310e1fff com.apple.qmaster.SwampExecutor 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
    0x319ea000 – 0x31ad0d9b com.apple.AECore 3.0.5 (3.0.5) /Library/Frameworks/AECore.framework/Versions/A/AECore
    0x31b65000 – 0x31ba3fff com.apple.compressor.ImageProcessing 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
    0x40d04000 – 0x40de9fe3 com.apple.compressor.StompTypes 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
    0x40e85000 – 0x40feeffb com.apple.compressor.transcoding 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
    0x410ff000 – 0x4114dfdf com.apple.compressor.StompUI 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
    0x4117b000 – 0x411bbfef com.apple.qmaster.SwampCore 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
    0x411fe000 – 0x4123bfff com.apple.qmaster.SwampTypes 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
    0x41280000 – 0x412c5fff com.apple.qmaster.do 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0x41317000 – 0x4135dfff com.apple.qmaster.ContentControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
    0x41398000 – 0x41459fff com.apple.qmaster.JobControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
    0x41501000 – 0x4151ffff com.apple.qmaster.SwampUI 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
    0x70000000 – 0x700e6ff2 com.apple.audio.units.Components 1.5.2 (1.5.2) /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0x71ffa000 – 0x71ffbfff com.apple.DVCPROHDVideoOutputCodec 1.3 (1.3) /Library/QuickTime/DVCPROHDVideoOutputCodec.component/Contents/MacOS/DVCPROHDVideoOutputCodec
    0x743f9000 – 0x743faff3 ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    0x74a12000 – 0x74cb0ff0 +org.perian.Perian 1.1.3 (1.1.3) <7baeef0d5eeb1d10d9b0c9293effe582> /Users/mike_halper/Library/QuickTime/Perian.component/Contents/MacOS/Perian
    0x8fe00000 – 0x8fe2db43 dyld 97.1 (???) <100d362e03410f181a34e04e94189ae5> /usr/lib/dyld
    0x90003000 – 0x900e3fff libobjc.A.dylib ??? (???) <7b92613fdf804fd9a0a3733a0674c30b> /usr/lib/libobjc.A.dylib
    0x900e4000 – 0x90196ffb libcrypto.0.9.7.dylib ??? (???) <69bc2457aa23f12fa7d052601d48fa29> /usr/lib/libcrypto.0.9.7.dylib
    0x90197000 – 0x9019ffff com.apple.DiskArbitration 2.2.1 (2.2.1) <75b0c8d8940a8a27816961dddcac8e0f> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x901a0000 – 0x901a0ff8 com.apple.Cocoa 6.5 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x901a1000 – 0x901c9ff7 com.apple.shortcut 1 (1.0) <057783867138902b52bc0941fedb74d1> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x901ca000 – 0x902fdfff com.apple.CoreFoundation 6.5.5 (476.17) <4a70c8dbb582118e31412c53dc1f407f> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x90304000 – 0x9060cfff com.apple.HIToolbox 1.5.4 (???) <3747086ba21ee419708a5cab946c8ba6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x9060d000 – 0x9060ffff com.apple.securityhi 3.0 (30817) <2b2854123fed609d1820d2779e2e0963> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x90610000 – 0x90610ffe com.apple.MonitorPanelFramework 1.2.0 (1.2.0) /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
    0x90611000 – 0x9063efeb libvDSP.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x9063f000 – 0x9065cff7 com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x9065d000 – 0x9069cfff com.apple.CoreMediaIOServicesPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
    0x9069d000 – 0x906b3fff com.apple.DictionaryServices 1.0.0 (1.0.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x906b4000 – 0x906b4ff8 com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x906b5000 – 0x90930fe7 com.apple.Foundation 6.5.7 (677.22) <8fe77b5d15ecdae1240b4cb604fc6d0b> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x90931000 – 0x909bcfff com.apple.framework.IOKit 1.5.1 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x909bd000 – 0x909f4fff com.apple.SystemConfiguration 1.9.2 (1.9.2) <01426a38ba44efa5d448daef8b3e9941> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x90a2a000 – 0x90b1eff4 libiconv.2.dylib ??? (???) /usr/lib/libiconv.2.dylib
    0x90b1f000 – 0x90b2dffd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
    0x90b2e000 – 0x90b2effc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x90b2f000 – 0x90ba9ff8 com.apple.print.framework.PrintCore 5.5.3 (245.3) <222dade7b33b99708b8c09d1303f93fc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x90baa000 – 0x90c78ff3 com.apple.JavaScriptCore 5525.26 (5525.26.2) <69e219e81bc886a94c4d4b310d393ab9> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x90c79000 – 0x90d03fef com.apple.DesktopServices 1.4.7 (1.4.7) <7898a0f2a46fc7d8887b041bc23e3811> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x90d04000 – 0x90fdeff3 com.apple.CoreServices.CarbonCore 786.11 (786.11) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x90fdf000 – 0x910aafff com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x910ab000 – 0x910b7ff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x910b8000 – 0x910befff com.apple.print.framework.Print 218.0.2 (220.1) <8bf7ef71216376d12fcd5ec17e43742c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x910bf000 – 0x910bfffe com.apple.quartzframework 1.5 (1.5) <4b8f505e32e4f2d67967a276401f9aaf> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x910c0000 – 0x911a1ff7 libxml2.2.dylib ??? (???) /usr/lib/libxml2.2.dylib
    0x911a2000 – 0x91235fff com.apple.ink.framework 101.3 (86) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x91236000 – 0x9137cff7 com.apple.ImageIO.framework 2.0.4 (2.0.4) <6a6623d3d1a7292b5c3763dcd108b55f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x9137d000 – 0x9154bff3 com.apple.security 5.0.4 (34102) <55dda7486df4e8e1d61505be16f83a1c> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x9154c000 – 0x91684fe7 com.apple.imageKit 1.0.2 (1.0) <2e354566521df8b1e3a78e9aeab5e6b4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x91685000 – 0x916a3ff3 com.apple.DirectoryService.Framework 3.5.5 (3.5.5) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x916ef000 – 0x9177bff7 com.apple.LaunchServices 290.3 (290.3) <6f9629f4ed1ba3bb313548e6838b2888> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x9177c000 – 0x91781fff com.apple.DisplayServicesFW 2.0.2 (2.0.2) <97878a73074e7da4fe31ea010a5d5ae1> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x91880000 – 0x91965ff3 com.apple.CoreData 100.1 (186) <8e28162ef2288692615b52acc01f8b54> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x91966000 – 0x919c3ffb libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
    0x919c4000 – 0x91a20ff7 com.apple.htmlrendering 68 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x91a21000 – 0x91a23ff1 com.apple.QuickTimeH264.component 7.6 (1290) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x91a24000 – 0x91acbfeb com.apple.QD 3.11.54 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x91acc000 – 0x91b7cfff edu.mit.Kerberos 6.0.12 (6.0.12) <685cc018c133668d0d3ac6a1cb63cff9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x91b7d000 – 0x91b7dfff com.apple.Carbon 136 (136) <98a5e3bc0c4fa44bbb09713bb88707fe> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x91b7e000 – 0x91bf0fff com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x91bf1000 – 0x91c09ff7 com.apple.CoreVideo 1.6.0 (20.0) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x91c5c000 – 0x91c5cffd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x91c5d000 – 0x91d17fe3 com.apple.CoreServices.OSServices 226.5 (226.5) <25243fd02dc5d4f4cc5780f6b2f6fe26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x91d18000 – 0x91ed4ff3 com.apple.QuartzComposer 2.1 (106.13) <40f034e8c8fd31c9081f5283dcf22b78> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x91ed5000 – 0x91eeaffb com.apple.ImageCapture 5.0.1 (5.0.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x91eeb000 – 0x91f29ff7 libGLImage.dylib ??? (???) <1123b8a48bcbe9cc7aa8dd8e1a214a66> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x91f2d000 – 0x91ff6fef com.apple.QuickTimeMPEG4.component 7.6 (1290) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x91ff7000 – 0x92001feb com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x92002000 – 0x92081ff5 com.apple.SearchKit 1.2.1 (1.2.1) <3140a605db2abf56b237fa156a08b28b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x92082000 – 0x920c4fef com.apple.NavigationServices 3.5.2 (163) /System/Lib
    John Pale replied 17 years, 4 months ago 6 Members · 16 Replies
  • 16 Replies
  • Kevin Monahan
    May 8, 2009 at 11:31 pm
  • Mike Halper
    May 8, 2009 at 11:45 pm
    Yes. I also repaired permissions and ran the sudo periodic daily, weekly, and monthly commands in terminal (not sure if those would actually help though). I also reinstalled Looks and the Multibridge Pro drivers.
    _______________________________________________
    Mike
  • Andy Mees
    May 9, 2009 at 12:46 am
    [Mike Halper] “The FCP crash report is below. Sorry for pasting the entire report, but I don’t know what to really look at to determine the cause.”
    Well right up top of the report is states “Crashed Thread: 0 ” so you need only post Thread: 0.
    And all that gobbledygook in Thread 0 seems to suggest that the exception (crash) was caused within the the graphics layer routines stemming from calls to Quartz Composer … don’t know that that helps you much except to allay your fears that its your Multibridge. More likely its FxPlug plugin related. What Mac are you using, what Graphics card?
  • Kevin Monahan
    May 9, 2009 at 1:05 am
    If it is a Quartz Composer issue, I’d be looking at any plug-ins applied from FX Factory or CHV. Do you have any of those applied?
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Mike Halper
    May 9, 2009 at 1:23 am
    I have a Mac Pro 8-core 3.0 GHz, 9GB RAM, ATI Radeon X1900 running 2 30″ Cinema displays. If I remember right I got it in September 2007.
    Mike
  • Mike Halper
    May 9, 2009 at 1:24 am
    I don’t have FX Factory, but I do have CHV Silk and Fog 4.0 in my Plugins folder. It’s not applied to any clips in this project though. I used it for another project that has since been completed.
    Mike
  • Mike Halper
    May 9, 2009 at 3:08 am
    Hey thanks for your responses and help guys. Another thought… Is it possible to generate a report of what filters are being used on which clips? This is an old project that has gone through numerous stages of color correction of the last few years. I’m wondering if it’s possible there’s a filter applied to a shot somewhere causing this. I’m 99.9% sure I removed all filters before starting work with Looks, but there’s hundreds of cuts so I suppose it is possible. Would take a long time to check each cut individually. Thanks again for the help.
    Mike
  • Rich Rubasch
    May 9, 2009 at 3:10 am
    I read your crash report thoroughly and on line 4673 it might indicate that the processor was cycling at the time of the crash with a FCP routine.
    Dude…that is a whopper of a report.
    How about creating a new project and copying only part of the sequence to a new sequence in the new project an see if the timeline crash still occurs.
    Hmmm..
    Rich Rubasch
    Tilt Media
  • Mike Halper
    May 9, 2009 at 3:26 am
    I could try that. Is it possible the project file size is too large? Originally is was 213 MB. Then I deleted all the old sequences and saved it as a new project. It’s now 137 MB and seems to crash less often.
    Mike
  • Mike Halper
    May 9, 2009 at 3:35 am
    Okay, it just crashed again and the crash report is identical on Thread 0 which is the one that crashed. Every character about the crashed thread in the report is the same. Does that mean anything?
    Mike
