Activity Forums AJA Video Systems FCP 6.0.5 and IO
  • FCP 6.0.5 and IO
    Posted by John Watts on January 27, 2010 at 3:16 am
    Trying (with no previous experience) to get an AJA IO to work with FCP on a MacBook Pro to digitize from dvcpro deck. Going into AJA IO with SDI and out to Firewire 400. Having no luck getting the FCP to see the firewire. I was given what I was told were latest drivers and loaded them successfully.
    This is a remote situation with rented gear, so wish me luck….please…no really…
    Kinga Brooks replied 16 years, 7 months ago 4 Members · 5 Replies
  • Jeremy Garchow
    January 27, 2010 at 4:59 am
    Are you using FireWire drives? Firmware updated on the io? Installed control panel? Using the io easysetups?
  • John Watts
    February 1, 2010 at 1:50 pm
    Thanks for the help. I wasn’t able to get the SDI to work, even though the digital drivers were installed and selectable for some reason. But the component with analog audio worked fine. Drivers and firmware seemed to be up to date. Anyway, got through the project. Thanks again.
    John Watts
  • Jeremy Garchow
    February 1, 2010 at 2:00 pm
    You probably just needed to install the sdi based easy setups.
  • Nick Price
    February 9, 2010 at 1:52 pm
    Is this mr watts from west london…ex-evanswoolfe….hope you got it sorted.
    if not give me a ring…
    nick
  • Kinga Brooks
    February 16, 2010 at 12:41 am
    Hello,
    I am experiencing similar problem: FCP 6.0.5, AJA software version 6.0.3, System: 10.5.8
    Log and Capture window confirms the signal from VTR, I can move the buttons, but the only thing I see are blinking green stripes in the bottom of black screen.
    Please advise.
    Thank you,
    Kinga
