Activity Forums Apple Final Cut Pro Legacy FCP 6.0.4 Crash, please help !!!
  • FCP 6.0.4 Crash, please help !!!
    Posted by Marko Dobrijevic on January 11, 2009 at 3:21 am
    When FCP 6.0.4 start and crash I get this message report…
    Process: Final Cut Pro [297]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 6.0.4 (6.0.4)
    Build Info: FCPApp-806171150~2
    Code Type: X86 (Native)
    Parent Process: launchd [131]
    Date/Time: 2009-01-11 04:06:58.898 +0100
    OS Version: Mac OS X 10.5.5 (9F33)
    Report Version: 6
    Exception Type: EXC_CRASH (SIGABRT)
    MASSIVE ERROR CODE NOTICE ABOUT FOUR PAGES LONG REMOVED BY CREATIVE COW ADMIN
    PLEASE HELP… 😀
    Asher Castillo replied 17 years, 7 months ago 3 Members · 2 Replies
  • Rafael Amador
    January 11, 2009 at 5:04 am
    Hi Marko,
    Some times the last few lines off those “crash reports” can give you a cue about was the application was doing when crashed, but are mostly impossible to be understood by video editors.
    When FC crash on opening normally is because is unable to load a component of the application/QT or is found a problem with the project or the media in the project you are opening.
    DEpending on the moment that it crashed I would go from rebuilding directories, put the media off-line, trashing preffs, or reinstall the last update.
    Rafael
    http://www.nagavideo.com
  • Asher Castillo
    January 11, 2009 at 7:36 am
    Try trashing prefs and running permissions from Disk Utility. If still a problem open an autosave project and see if that helps.
