Activity Forums Apple Final Cut Pro Legacy FCP 6.0.3 hangs on render under new leopard update
  • FCP 6.0.3 hangs on render under new leopard update
    Posted by Jim Kinsey on June 1, 2008 at 10:01 pm
    Rendering DV anamorphic in FCP 6.0.3 with latest version of leopard. First, my machine renders and I can see the HDpro 4TB rendering away but it hangs up at 44% sometime 98% and FCP freezes then I do a hard shut down because I can’t force quit the final cut. I am on the latest MAc PRo 3.2GHz 8 gigs of ram and unfortunately just upgraded to leopards latest update. Everything worked perfectly before??? Any takers?
    Jim Kinsey
    Jim Kinsey replied 18 years, 2 months ago 7 Members · 10 Replies
  • 10 Replies
  • David Roth weiss
    June 1, 2008 at 11:10 pm
    Use render manager to delete all renders for that timeline and then rerender. Can’t promise that will fix you up, but it just might.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY â„¢
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Jim Kinsey
    June 2, 2008 at 12:45 am
    Thanks I will try that. Man 30 hard shut downs today. When I force quit FCP it still stays open in the doc and I can not restart or shutdown normally so my only option is to hold down the power button until everything powers down… Really fried right now… For a second I was having PC flashbacks.
    Jim Kinsey
  • Steve Eisen
    June 2, 2008 at 12:53 am
    That many hard shutdowns is a lot for your system hard drive.
    You also might want to try trashing your preferences.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Glenn Grant
    June 2, 2008 at 1:31 am
    I had this same kind of thing happen, but I am still on 10.5.2. I was able to narrow it down to one clip that was giving me trouble. It was just b-roll so I used a different shot. I wish I had tried the render manager. The shot played fine on it’s own it was just trouble with a lower third that needed to be rendered.
    So this may not be a problem with 10.5.3
  • Alexander Kallas
    June 2, 2008 at 2:13 am
    Get the latest licence of Disk Warrior, you’ll need it !
    Cheers
    Alexander
  • Rafael Amador
    June 2, 2008 at 9:36 am
    I second Alexander: DiskWarrior.
    I’ve up-dated lLopard last week and the only problem I found is that I can not bring to FC the clips compressed with Sheer. I’f do it, “General Error”. However they play fine in QT.
    The rest the same in FC. No better, no worst. Still lazy for closing.
    I didn’t try to reproduce the bugs of FC, Color or Compressor. After holidays.
    Rafael
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Jim Kinsey
    June 2, 2008 at 12:56 pm
    So I trashed the preferences files then deleted the render files and re-rendered. It seemed to work for now. So the real test will come today while I start round 2 with the remainder of shows to print to tape. Thanks for all your input. I know better than to update my machine in the middle of 13 original episodes for TV. I will call CAl digit today and find out if their HDpro needs an update with leopards latest installment.
    Jim Kinsey
  • Jim Kinsey
    June 4, 2008 at 4:41 am
    Well I spoke with the folks at cal digit as I have an HD pro raid 4TB model and they are working feverishly to fix a kernal that their raid hangs on in the new leopard update. So when I go to render the caldigit raid hangs half way through or sometimes at 95 or 98% and FCP feezes and will not force quit. after a hard shutdown….. The only fix I have found to help out is when you use the shortcut option+r just render small bits at a time by hitting escape after maybe 10% and then do that again and again until it has just a small amount left then you can let it finish rendering. This seems to be working as a work around.
    With that being said CAl digit informs me they will have a patch on their site this week to fix the problem.
    Jim Kinsey
  • Cade Muhlig
    July 11, 2008 at 5:44 am
    I have the same problem. Ive done probably around 10 hard shutdowns today. FCP is actually frozen as I type this. Im running on a Cal Digit too
  • Jim Kinsey
    July 12, 2008 at 12:14 am
    Cal- Digit has the fix. Go to their website and tech support for updates and you can fix it by following the instructions.
    JK
