Activity › Forums › Apple Final Cut Pro Legacy › FCP 6.0.2 P2 Import Problem
Posted by Michael Ruiz on February 5, 2008 at 1:17 amHi All
When in the Log and Transfer window
I get a Red Unkown Error when importing P2 media.
The media is good / tested on FCP 5. Seems like a bug?Any help would be appreciated.
Sorry if this posting is a duplicate. I had Log In issues..
Michael
FCP 6.0.2 / Qt 7.3.1
Tiger 10.4.11
Fast / Recently Wiped G5
No AE / FCP pluginsJeremy Garchow replied 18 years, 7 months ago 3 Members · 9 Replies -
Jeremy Garchow
February 5, 2008 at 3:41 am1)make sure you have the codecs/drivers from Panasonic:
https://www.panasonic.com/business/provideo/support/software_downloads.asp
2) Upgrade fxfactory if you have it
https://docs.info.apple.com/article.html?artnum=307062
3) uninstall Perian if you have it
https://docs.info.apple.com/article.html?artnum=306922
Michael Ruiz
February 5, 2008 at 4:10 amThanks Jeremy..
I did the suggested and still have error messages.
I don’t get it.Is there a specific codec from Panasonic that I am missing?
I downloaded the driver..Thanks Again
mr
Jeremy Garchow
February 5, 2008 at 4:16 amAs long as you have FCP installed, yes.
Try turning off the ‘Remove Duplicate Frames’ option in the log and transfer window preferences (the little gear looking thing).
What format is your footage?
Michael Ruiz
February 5, 2008 at 4:31 amThe footage is DVCPRO HD 720 60
This could be the issue.I’ve been able to import DVCPRO 50
I’ll give turning off “Remove Duplicate Frames” a try.
I need to step away from the studio for the evening.
I have a sick child at home.I’ll leave a response i the AM
Thanks you for the help…
If you have any other ideas leave a note and I’ll try them in the morning
Thanks Again…I do appreciate your time!!!
Michael
Jeremy Garchow
February 5, 2008 at 4:34 amChecking the ‘remove duplicate frames’ box should do it, especially for 720p60 footage.
Hope the kid’s okay.
Jeremy
Walter Biscardi
February 5, 2008 at 1:06 pmHave you reviewed Shane Ross’ tutorial on P2 import?
https://library.creativecow.net/articles/ross_shane/p2fcp6.php
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Michael Ruiz
February 5, 2008 at 7:27 pmThanks for all the support Jeremy and Walter
In the Log and Transfer preferences pull down I unchecked
the “remove advanced pulldown and duplicate frames” box and the media imported easily.I also viewed the Tutorial by Shane Ross, Thanks Shane!!
Until the next FCP issue…
m i c h a e l
