Activity › Forums › Apple Final Cut Pro Legacy › FCP 6.01 crashes on export to Compresor 3
  • FCP 6.01 crashes on export to Compresor 3
    Posted by Eoin Mccaffrey on March 9, 2008 at 5:43 pm
    hi there y’all
    i am having a 90% failure rate when exporting from FCP6.01 to Comp3.
    my set up is as follows
    FCS 2 on a clean and updated install of Mac os x 10.4.11(back 2 back)
    QT pro updated and installed prior to FCS 2 install.
    2.16ghz Intel Core 2 Duo with 1 Gb 667mhz DDR2 SDRAM
    I am working with Dv footage from a Canon XL2(capture device)
    Proj files stored on Mac HD and captured footage on Lacie 500gb via FW 400
    i have being working until the upgarde to FCS2 on FCP 5.1.4 and Compressor 2.so i have some expeience with both apps.the older versions never or next to never suffered any app crahes like i am having now.
    my problem is as follows.Prep and render my Seqs usually about 120minsRT total. in 45 min seqs. after exporting 1st seq FCP6.01 crashes as a work around i have just had to export one seq at a time ,force quit and reopen FCP and export next Seq and build a batch this way. Now after 2 exports when possible Comp3 crashes and so on.
    Will a ram upgrade solve this?(are FCP6 and Comp3 ram intensive?)
    will the upgrade to Comp3.01 solve this?
    do i have to rip out Comp3 and try to reinstall which i believe is tricky?
    Is FCP 6.01 the very latest or are there upgrades available?
    will exporting as a Qt self contained or such like help?
    please help this is day 3 in no where ville
    eoin
    Walter Biscardi replied 18 years, 6 months ago 2 Members · 1 Reply
