Activity Forums Apple Final Cut Pro Legacy [ FCP 6.0] synchronization and rescue clip
  • [ FCP 6.0] synchronization and rescue clip
    Posted by Duca Simone luchini on August 24, 2009 at 11:00 pm
    [ FCP 6.0] synchronization and rescue Clip
    Hello world,
    I have a Clip ( DV PAL ) That e'venuta out of sync.
    Then put it in TL and I did sync but
    When I use it later in the sequences, It my
    Loses again synchronous (for example if I put
    Effect as a, A crop, Etc.). So I thought
    Altor to cut the head and do the sync and
    Then export to make a copy of the same
    Format, But synchronized, Nevertheless still
    Out of sync…Little…
    Procedure:
    I put the Clip in a sequence only
    Synchronize,
    Do synchronization, Then select the
    Clip and I: File / export / using quicktime
    Compression and then saved in DV PAL (.Mov)
    Cioe'esattamente identical to the original
    Clip.
    He is still out of sync!!!!!!!
    How do?
    Duca Simone luchini replied 17 years ago 2 Members · 2 Replies
  • Rafael Amador
    August 25, 2009 at 12:39 am
    Hi Maurito,
    Try to open it in QT and save (Save as..) it with a different name.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Duca Simone luchini
    August 25, 2009 at 9:44 am
    Hi Rafael,
    unfurtunately your advice doesn´t work… i´m desperate…
    it´s so strange. I´ve another clips not syncronised but i didn´t have problem…
