Activity Forums Apple Final Cut Pro Legacy FCP 6.0 not recognizing firewire
  • FCP 6.0 not recognizing firewire
    Posted by Renata Sheppard on June 22, 2007 at 11:22 am
    I just installed FCP 6.0 (had version 5.0) and now it doesn’t recognize my VX2000 (I checked and the DV port is on). I tried reinstalling Quicktime for some reason but that didn’t help. FCP opens and when I go to log and capture it is “unable to initialize video deck”.
    Help!!
    Renata Sheppard
    Popoyman replied 19 years, 1 month ago 4 Members · 3 Replies
  • Jerry Hofmann
    June 22, 2007 at 1:27 pm
    When you reinstalled QT (which was a good idea BTW) did you trash the receipts for it first? if not try that and reinstall again.
    If that fails, you might try resetting your PMU button found on the motherboard with your Mac disconnected from power entirely.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Soreyrith Um
    June 22, 2007 at 2:41 pm
    My Mac Pro didn’t recognized my camcorder when I used the firewire connector in the front of the computer. But for some reason, the connector in the back worked.
    http://www.HotSpotsOnline.com
  • Popoyman
    August 2, 2007 at 5:53 pm
    Everytime I try to capture video from my SONY DCR-TRV11, the following message pops up: “Unable to initialize video deck.” I tried to capture on my copy of Final Cut Express, as well as on my friend’s Final Cut Pro 5, with the same results. However, both versions of final cut were able to recognize my friend’s VX2100. Is this a hardware issue? How can I begin to capture from the DCR-TRV11?
