Activity Forums Apple Final Cut Pro Legacy fcp 6 wants pal?
  • fcp 6 wants pal?
    Posted by Mike Dunn on April 13, 2009 at 8:31 pm
    HI,
    Recently upgraded kona LHe firmware to deal with a popping issue with audio. Pops are gone but now FCP keeps forcing the card into 625 (pal) mode when capture is initiated. Trashed the settings, tried working from the FCP presets in easy setup and tried setting up a NTSC preset in AJA control panel. No luck.
    Jeremy Garchow replied 17 years, 4 months ago 4 Members · 3 Replies
  • Jerry Alto
    April 13, 2009 at 10:05 pm
    Mike- You might want to try the KONA forum.
    Jerry
    G5 Dual 3GB Ram
    FCP Studio 6.02
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
    GV-HD700
  • Michael Gissing
    April 13, 2009 at 11:39 pm
    Pardon my mirth, but what a welcome change to hear of a system defaulting to PAL (the most used system in the world) instead of NTSC.
    I am sure that there will be something simple like system preferences to fix it but I don’t know the Kona LHe so I can’t help.
  • Jeremy Garchow
    April 14, 2009 at 3:26 am
    DId you upgrade the drivers too? If so ry uninstalling the drivers, restart, then reinstall the drivers.
