Activity Forums Apple Final Cut Pro Legacy FCP 6 Unexpectedly Quitting
  • FCP 6 Unexpectedly Quitting
    Posted by Kris Lee on June 24, 2010 at 8:01 pm
    I’ve deleted the FCP program preferences and verified the system and external hard drive disks. FCP usually runs smoothly for a solid hour or two, then it’ll expectantly quit and continue to quite within minutes of startup thereafter. Perhaps I am not deleting the correct preferences? Under FCP User data there’s the standard FCP 6.0 Prefs and FCP Prof Cache, which I deleted, then there’s a sub folder called FCP 6 Rescue (I’m not sure if this is a program that was previously installed before I worked with this computer) that has FCP 6.0 Prefs, FCP Obj Cache, FCP Prof Cache then .com.apple.FinalCutPro.plist, should these be deleted as well? Would a program like Disk Warrior be helpful here?
    Alan Thorburn replied 16 years, 2 months ago 2 Members · 5 Replies
  • Alan Thorburn
    June 24, 2010 at 10:02 pm
    Try turning off your file sharing.
    Alan
  • Kris Lee
    June 25, 2010 at 4:46 pm
    My file sharing was turned off already..
    Thanks for the suggestion though 🙂
  • Alan Thorburn
    June 25, 2010 at 5:28 pm
    Is FCP crashing only in one project or all projects?
    Try creating a new project, copy all your media to a different drive, and then re-import, re-link.
  • Kris Lee
    June 25, 2010 at 8:08 pm
    Yes, I think this is the problem.. as I’m only having this problem with FCP projects on my external, should I run repairs, or reformat the external, then dump the files back onto it?
  • Alan Thorburn
    June 25, 2010 at 9:48 pm
    I would copy your media files off the external drive to another drive, then re-import/re-link those into your project. If your external drive is dying, better to do this sooner than later. Consumer HDs have a high failure rate when used in video editing. Try running your disc utility program and see if anything shows up.
