Activity Forums Apple Final Cut Pro Legacy FCP 6 stops capture- dropped frames- bad HD card?
  • FCP 6 stops capture- dropped frames- bad HD card?
    Posted by Dale Larsen on March 24, 2008 at 5:30 am
    First off I want to say that I get a lot of great info from all of you on this forum. I Really value this tool we have here.
    I have some Varicam material that I have been trying to capture at uncompressed 10 bit but it ALWAYS drops out with the dropped frame message. it involves a lot of layers so i’d like to keep the quality up.
    I have a Deck link HD, (4yrs old) and have been trying a variety of blackmagic codecs.
    DVCPRO HD 720 or 1080 no problem with carture
    8 bit 720 no problem.
    10 bit 720, drops out
    I seem to have a data rate issue.
    I have a 3.6TB internal sata raid (mirrored).Should it be a Stripped raid?
    raid is empty.
    dual 2.0 G5
    6gig memory
    Can these HD Cards go funky?
    It has locked up on me once today (no picture til i reboot machine)
    and when left to batch capture a tape, it stops the transfer cause “timecode breaks”were encountered.
    This tape has no breaks, since i imput it at low res just an hour ago- no TC breaks.
    reboot the Mac and the tape captures without a hitch.
    the card is becoming suspect, yes?
    perhaps I should pull it and re seat it in the slot.
    Deck link speed test is 220megs/s out & 216m write.
    thats fast enough for 10 bit uncompressed, isn’t it?
    any thoughts?
    Dale Larsen replied 18 years, 6 months ago 3 Members · 5 Replies
  • Shane Ross
    March 24, 2008 at 5:32 am
    Dropped frames…that points to drive speed. Yeah, they should be striped, not mirrored. Mirrored is too slow.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Dale Larsen
    March 24, 2008 at 4:26 pm
    I will re format the raid and see what happens.
    So the card is not suspect?
  • Shane Ross
    March 24, 2008 at 5:52 pm
    Doesn’t sound like an issue with the card…sounds like a slow drive issue. RAID properly first, then see.
    Shane
    http://www.LFHD.net
    Read my blog!
  • Del Chapple
    March 24, 2008 at 6:23 pm
    Intel mac or G5? i ask because a new intel mac will do prorez which is much less demanding on disks but you need a lot of processors on board to compress on the fly, a g5 wont cut it.. Uncompressed 720p is rather demanding on data 160MB/s or so. maybe defrag the drive. if you get enough open pasture to write the data, you might survive..?
    d
    you cant hear my inner voice scream… can you..?
  • Dale Larsen
    March 24, 2008 at 10:29 pm
    Shane,
    I re formatted to a “stripped” raid and now I can capture 10 bit, but only from the 1200 A deck. (also 1080 8 bit)
    so restripping was definate progress.
    what about (journaled) or not?
    I have a couple of “B”roll that are on Sony HDV (Z-1) and have tried to input that, but the system will not accept it, even at 8 bit. (dropped frame error)
    the signal IS passing through 2 converters to get it to 720 HDSDI. perhaps the 2 coverters are part of the issue.
    if I can capture 720 8 bit from a 1200 deck, then I should be able to capture 720 8 bit from the converters? yes/no?
    thanks for the valuable info
    seems logical enough.
