Activity › Forums › Apple Final Cut Pro Legacy › FCP 6 scratch in FCP 5?
  • FCP 6 scratch in FCP 5?
    Posted by David Barela on December 12, 2008 at 7:19 pm
    Greetings Earthlings! I’m new to these forums, and usually get my answers from browsing but found no help. My question is this, is there a way to edit footage captured in FCP 6 in FCP 5? I want to do some editing over the holiday break (I work for a University) but can only get a licensed copy of FCP 5. Any help, or workaround’s will be greatly appreciated.
    Thanks in advance,
    David C. Barela
    Production Assistant
    Media Productions
    New Mexico State University
    Dennis Leppell replied 17 years, 9 months ago 2 Members · 1 Reply
  • Dennis Leppell
    December 12, 2008 at 8:03 pm
    You should be able to edit in FCP5 if captured w/ FCP6, so long as you’re using the same version of Quicktime, but you’ll need to start a new project and add the clips manually. Final cut projects are not compatible with previous versions, even if it’s only a point upgrade.
