Activity Forums Apple Final Cut Pro Legacy FCP 6 ~ ProRes
  • Posted by Caleb Henderson on December 21, 2009 at 1:52 am
    hey y’all, I’ve got a question about my final cut pro 6, I have some footage taken with a Sony FX-7 and want to edit it. The audience will be watching it on DVD in SD, so I was reading on this forum that editing it in ProRes would be the thing to do (I’m a first timer to shoot in HDV). It looks like the thing to do is capture in ProRes like Chris’s tutorial says, but the problem I have is that I don’t have the capture preset for ProRes. Do I need to upgrade to PCP 6.0.2 to get it? If so, what would be the easiest way?
    Also on my MacBook Pro there is only one firewire port, so I’m using that to attach to the Camera and attaching my external hardrive using a usb port.. Is using the usb port going to be a problem..
    thanks for the help guys.
    Caleb
    Adam White replied 16 years, 9 months ago 3 Members · 2 Replies
  • Sverker Hahn
    December 21, 2009 at 10:59 am
    Upgrade FCP.
    Some people use ProRes, some don´t.
    I have not seen any improvement in quality when I used ProRes.
    Use Compressor.
    Choose the setting for DVD – best quality 90 min.
    Copy this setting and activate “Frame controls” which increases quality.
    Save the new setting and use it further on
    Sverker Hahn, Stockholm
    Slower is better!
    Sony EX1
    Final Cut Studio 2
    iMac Intel
    MacBook Pro 15″
  • Adam White
    December 21, 2009 at 10:44 pm
    Hi Caleb,
    Capturing your HDV material with ProRes won’t automatically give you superior [i]image[/i] quality; the key is that ProRes RETAINS greater image quality after several renders and the application of video filters e.t.c. as opposed to other codecs. But, the main reason ProRes is so great to use when working with HDV content is that it is far better suited to the editing process then the native HDV codec – using ProRes will reduce your render times when adding filters e.t.c. and I’ve also noticed that it really cuts compression times when you’re compressing your final cut for SD DVD. ProRes is generally better to work with if you’re doing any kind of extensive colour grading, too – in my experience.
    The big drawback is that the ProRes format produces very large files (about 60GB per hour of HDV). I don’t know what capacity your scratch disk has – but keep that in mind. As for working with ProRes over a USB connection – personally I would be quite dubious about that. There is a good discussion about this here; https://forums.creativecow.net/thread/8/1000834. The other “solution” would be to capture the files to your macintosh HD during the capture and then transfer them to a FireWire drive afterwards before you start editing. Again – this is not ideal and I know many people would shoot me for even suggesting it! But if your options are limited…
    It really boils down to; is this project going to require many video filters/visual effects? If so, ProRes will save you a great deal of time that will otherwise be wasted rendering HDV files and it [i]does[/i] seem to just work more harmoniously with Final Cut (I used to edit with HDV but would never do so now).
    Best,
    Adam
