Activity Forums Apple Final Cut Pro Legacy FCP 6 ProRes Export Produces Gamma Jumps in QT Player
  • FCP 6 ProRes Export Produces Gamma Jumps in QT Player
    Posted by Jeff Coleman on July 9, 2010 at 9:19 pm
    MacPro (Fall ’07)
    10.5.8
    8GBs RAM
    FCP 6.0.6
    QT Player 7.6.4/7.6.6
    Edited ProRes 422 timeline and exported quicktime movie via File/Export/QuickTime Movie.
    When I play the movie back in QT Player (7.6.4 or 7.6.6 on same machine or a different machine makes no diff) the movie has jumps in gamma level in the vicinity of dissolves (15f, 1 per 64f). It kinda looks like it’s an additive dissolve that somehow the additive part just suddenly kicks on on the first frame of the dissolve to sort of turn the lights on. One frame is fine, but the next boosts the video or at the end of the dissolve the incoming video is boosted until the dissolve ends and then the next frame is fine. However, I don’t see this happening at every dissolve, mostly the darker scenes. If QT Player preferences has checked “Enable Final Cut Studio compatibility” then there is no problem.
    If I play the movie back inside Compressor then I see no problem.
    If I take the dissolves out of the FCP timeline then I see no problem.
    If I export by changing the settings from current to Uncompressed 10bit, then I don’t see a problem.
    If I change the sequence codec to ProRes 422 (HQ) then I see no problem.
    I’ve tried these things on older clones as far back as FCP 6.0 QT Player 7.6.4 and the problem is consistent.
    If I take the FCP project and read it into a machine running FCP 7 and export a QuickTime Movie then I see no problem. But the movie that the MacPro 6.0.6 made will play on that machine with the gamma jumpiness.
    Regarding standard troubleshooting: PRAM reset, permiss repair, FCP prefs trashed, disk repair, new user created, old clones from last fall used to verify, etc.
    Can anyone else confirm this on their machine running FCP 6 with an Apple ProRes 422 timeline with frequent dissolves?
    Any ideas?
    Jean Mathis replied 11 years, 2 months ago 5 Members · 12 Replies
  • 12 Replies
  • Gary Adcock
    July 9, 2010 at 10:35 pm
    When I play the movie back in QT Player (7.6.4 or 7.6.6 on same machine or a different machine makes no diff) the movie has jumps in gamma level in the vicinity of dissolves (15f, 1 per 64f) .
    RT extreme always renders @8bit, your RT renders is not forced into 10 bit until you use the HQ or 4444 version of ProRes.
    What was your originial acquisition format?
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Technology Development
    Quality Assurance Assistance
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Jeff Coleman
    July 10, 2010 at 3:55 pm
    I’m missing the relevance of RT Extreme in this case.
    Original acquisition is a mix of ProResHQ and ProRes footage.
  • Neil Sadwelkar
    July 10, 2010 at 5:48 pm
    I’ve observed this in FCP 6.0.x. With an HD 1080p24 ProRes sequence with subtitles. It would jump in brightness in this sections that subtitles. Strangely, the exported QT showed these artifacts within QT Player on the Mac screen. But the same expiated QT when imported back into FCP nd played out as video in a timeline out through a Blackmagic Multibridge, it was clean.
    Could be wrong but I haven’t seen this in FCP 7.0.2
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Jeff Coleman
    July 11, 2010 at 10:00 pm
    Neil,
    Thanks for the post.
    Good to hear a confirmation.
    I too haven’t noticed this in FCP 7.0.2.
    Thanks again.
  • Jeff Coleman
    July 11, 2010 at 11:53 pm
    notice Fredy’s similar problem in this post:
    https://forums.creativecow.net/thread/8/1094526
  • Gary Adcock
    July 12, 2010 at 3:29 pm
    [Neil Sadwelkar] ” With an HD 1080p24 ProRes sequence with subtitles. It would jump in brightness in this sections that subtitles.”
    [Jeff Coleman] “I’m missing the relevance of RT Extreme in this case. “
    do you have RT extreme turned on in your timeline?
    if so you are using it for all of your renders, that is where the problem lies since your codec is 10bit but you are telling the time line to render in 8bit by using the RTX engine. The addition of the subtile has triggered the gamma issue because titling is seen by FCP as an RGB+ alpha file, and those are issues not fixed until FCP 7.
    gary adcock
    Studio37
    Chicago, IL
  • Jeff Coleman
    July 12, 2010 at 5:31 pm
    Let me see if I have that point correct regarding RT Extreme in FCP.
    If I create a 10bit timeline (ProRes, Uncompressed, etc.),
    BUT I have RT Extreme turned on, then my movie output will be rendered as a 10bit movie from 8bit renders within it? The clip is 10bit, but that effect between them is rendered as 8bit. When QT Player sees a 10bit clip against an 8bit render the gamma jumps. When Compressor or FCP see it, they’re happy as clams. In other words, it doesn’t matter what the timeline codec is (in terms of bits), or what you’ve set the video processing tab to be (again in terms of bits) as long as RT Extreme was turned on when you rendered any effects. So RT Extreme trumps Video Processing settings?
    Have I summarized accurately?
    How do you turn off RT Extreme? My selections are “Safe RT” or “Unlimited RT”. I don’t seem to have an OFF selection.
  • Gary Adcock
    July 12, 2010 at 7:19 pm
    [Jeff Coleman] “If I create a 10bit timeline (ProRes, Uncompressed, etc.), “
    OK. there is no RTX with uncompressed formats.
    [Jeff Coleman] “BUT I have RT Extreme turned on, then my movie output will be rendered as a 10bit movie from 8bit renders within it?”
    not the video itself, but anything that is generated or altered( filters or CC) inside of FCP may be effected, ESPECIALLY when working with FCP6 that is still using the older QT engine ( and while Neil in FCP 7 is not seeing the same issues)
    “When QT Player sees a 10bit clip against an 8bit render the gamma jumps.”
    The graphic overlay is at the heart of the issue, internally graphics are created as RGB+alpha-
    Add that RGB data and that transition between clips would be something that highlights the gamma issue since you are moving from a 10bit PR image + an RGB graphic into an 8 bit transition (due to RTX processing) and then back to 10bit video content –
    Anytime that QT jumps from 10bit to 8bit around a RGB clip there always seems to be issues.
    Note that the QT player always plays back as 8bit on both platforms.
    [Jeff Coleman] ” So RT Extreme trumps Video Processing settings? “
    You overrode what you thought were your settings were by using the RTX engine, you told the app that it was OK to handle everything at 8bit.
    You made a decision- it gets down to do you want speed or quality?
    Avid, Adobe and Apple all handle video processing in this general manner with regards to 10bit material with accelerated video processing. as Neil said FCP 7 does solve a good number of these color conversion issues.
    gary adcock
    Studio37
    Chicago, IL
  • Jeff Coleman
    July 12, 2010 at 7:35 pm
    Thanks for that clarification.
    How do you turn RT Extreme off then (see previous post)?
    [gary adcock] “you are moving from a 10bit PR image + an RGB graphic into an 8 bit transition (due to RTX processing) and then back to 10bit video content -“
    I’m not. I’m just dissolving from a 10bit ProRes to a 10bit ProRes, perhaps at times dissolving from a 10bit ProRes to a 10bit ProRes(HQ). Color correction is applied to the clips.
    Why does FCP and Compressor play that movie back with no gamma shifts, while QT Player 7 does show gamma shifts?
  • Jeff Coleman
    July 16, 2010 at 7:48 pm
    The venerable Mr. Jordan has provided the following answer to the question regarding how to turn RT Extreme Off.
    “You turn off RTExtreme by going to the top left corner of the Timeline and setting the RT Menu to “Safe” and make sure the top setting says “Dynamic” and the bottom setting says “Full” or “All.”
    This is how I’ve had my settings:
    So I think RT Extreme has been off this whole time. While this has been an enlightening discussion, I don’t think it’s shed any light on this particular issue.
