Activity Forums Apple Final Cut Pro Legacy FCP 6 freezes while updating FCP 5 project to FCP 6
  • FCP 6 freezes while updating FCP 5 project to FCP 6
    Posted by Rachel Lears on January 25, 2008 at 10:05 pm
    Hi all,
    I have been trying to update a fairly large FCP 5.1 project to FCP 6. I’ve tried this on two machines (a powerbook G4 and a desktop G5) and in both places the program tells me its opening the project, then asks if I want to update. When I click yes, the program freezes and the project never opens. This happens repeatedly, after restarting, etc. The project gives me no problems in FCP 5. Any thoughts? Thanks so much!
    Rachel
    Boyd Mccollum replied 18 years, 7 months ago 3 Members · 2 Replies
  • Paul Escandon
    January 25, 2008 at 11:07 pm
    You can try as an alternative to that method (which definitely should work.. not sure why it’s not) exporting an XML file from Final Cut 5 and importing the XML file into Final Cut 6. You can do this from the File > Export and File > Import commands.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media – JPCU
    MacPro Quad-core XEON
    8Gb ram, ATI Radeon X1900 XT, 2TB internal RAID
    2 20″ Dell UltraSharps + Matrox MXO & 23″ ACD
  • Boyd Mccollum
    January 26, 2008 at 3:42 pm
    How long did you let FCP 6 try to open it? I went through a similar experience with a project file that was 200MB. It’d get to about 48% open, then ask if I wanted to update. Then it would just work and work and I would need to force quit FCP to stop it.
    I finally decided to let it run, and went out for a few hours, had dinner, etc. When I came back it had opened. It may be that it might just take a while to update – for sure it took longer than my patience allowed.
