Activity › Forums › Apple Final Cut Pro Legacy › FCP 6 compatibility with DV/Mini DV Decks
  • FCP 6 compatibility with DV/Mini DV Decks
    Posted by Robert Decker on September 15, 2009 at 9:19 pm
    Question…I have FCP 6 on my IMAC. Im looking to purchase a MiniDV/DV deck to log and capture into FCP via firewire. Any suggestions on compatible decks?
    I found a Sony DSR 30 and a JVC BR-DV600U for a reasonable price. Anyone know if those two are compatible with FCP 6?
    Bret Williams replied 17 years ago 5 Members · 4 Replies
  • Shane Ross
    September 15, 2009 at 9:29 pm
    They are.
    Shane
  • Arnie Schlissel
    September 16, 2009 at 2:19 am
    [Robert Decker] “I found a Sony DSR 30 and a JVC BR-DV600U for a reasonable price.”
    Those are both SD only decks. I’ve heard that this HD thing may take off someday.
    It’s the 21st century. Maybe you should be looking at a Sony HDV deck. It will play back miniDV tapes, but it will also play back Sony & Cannon HDV tapes. That will open up more possibilities for you right now than buying a used SD onlu miniDV deck.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Nick Price
    September 16, 2009 at 1:53 pm
    Arnie is right, But almost any camera with a firewire out port (also called iLink or IEEE1394) will work with FCP. I use an old sony consumer handycam sometimes.
    nick
  • Bret Williams
    September 16, 2009 at 2:22 pm
    Well the 30 is pretty useless. Doesn\’t support e to e which means if you want to bring in some other format through the deck,you\’d have to record it to tape first.
    The 600 has component in/out and maybe xlrs if I remember right, but only does miniDv, not DVCam or DVCPro.
    Both are pretty ancient. 10 years old or so.
