Activity Forums Apple Final Cut Pro Legacy FCP 6 and BiCoastal Post Workflow
  • FCP 6 and BiCoastal Post Workflow
    Posted by Taylor Wigton on August 31, 2008 at 6:54 am
    Hello. I hope this post is accepted, as I know there a certain rules against cross posting. I am a DP and CML is my home so to speak, but it was suggested to me that I redirect this question here or lafcpug.org. Thanks for your understanding! Below is the original post that I am submitting on behalf of my editor:
    BEGIN. We have 5 people who are all working in different areas of the country working on post for a film. All parties have the same media files organized in the same folder hierarchy on our drives. But when we exchange FCP (v6) project files, we still have to re-link all the media, as the project files point to the sender’s hard drive and don’t recognize the media on the other end. This is becoming especially tedious since we’re far enough along that we have color correction and filters that constantly need not only to be relinked but re-rendered every time we make even the slightest change to the timeline and pass along the file to the other members of the post team. END.
    ____
    So that’s that. Any suggestions would be greatly appreciated and many many thanks in advance!
    Taylor Wigton
    DP, Los Angeles
    Taylor Wigton replied 18 years ago 6 Members · 8 Replies
  • 8 Replies
  • Rafael Amador
    August 31, 2008 at 8:40 am
    What about using HDs with the same name?
    Rafael
    http://www.nagavideo.com
  • Taylor Wigton
    August 31, 2008 at 9:08 am
    would this literally mean what it says and should this problem no longer exist once the most recent FCP project file is uploaded onto our ftp and downloaded by all parties involved? when dave (editor) gets this message sunday am on the east coast, i don’t know if he will laugh or cry!
    THANKS, TAYLOR
    Taylor Wigton
    DP, Los Angeles
  • Walter Biscardi
    August 31, 2008 at 10:06 am
    Rafael’s suggestion is a simple one and should work, though FCP still might want to re-link the files since there will be changes to the media each time.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Shane Ross
    August 31, 2008 at 10:21 am
    I did this with a producer of mine. The same name hard drive is sound advice….same name and file structure.
    Renders will have to be re-rendered though. Those are specific to each system.
    Shane
  • Rafael Amador
    August 31, 2008 at 10:28 am
    Well, I really don’t know.
    I live beside the jungle and quite faraway from those workflows;-)
    I think the only thing that FC needs is that the files have exactly the same path. If the files are in HDs with different names can’t never have the same path.
    rafael
  • Mark Raudonis
    August 31, 2008 at 3:20 pm
    Shane’s right… name the hard drive EXACTLY the same for all systems and your relinking should be limited just to the renders.
    We’ve used this workflow for years with editors in different time zones and it works.
    As to the the renders… you must re render locally.
    Mark
  • Steven Gonzales
    August 31, 2008 at 4:27 pm
    If you can’t rename the hard drives to the same name, you could send XML around, and for each different system create a script (applescript, PERL, whatever) that performs a global search replace across the XML for the drive names.
    You could also do this in a text edit program with search and replace, if you got the context exactly right.
    But that is a lot of trouble.
  • Taylor Wigton
    August 31, 2008 at 8:51 pm
    It Worked! This is another reminder of the amazing power of the global cooperation and community spirit that is allowed to flourish on boards such as this. Great Stuff!
    Taylor Wigton
    DP, Los Angeles
