Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.1.4 update available
Posted by Harley Michailuck on February 23, 2007 at 1:00 amLooks like it may even have the Boris fixes along with the other plugin fixes.
Best,
HarleyHarley Michailuck
Brass Orchid Post fx
Saskatoon, SK CanadaJoe Murray replied 19 years, 6 months ago 7 Members · 7 Replies -
Walter Biscardi
February 23, 2007 at 1:51 am[Harley Michailuck] “Looks like it may even have the Boris fixes along with the other plugin fixes.”
Shows you just HOW broken FCP 5.1.3 really was. I’ve NEVER seen Apple release an update so fast.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Doug Olin
February 23, 2007 at 2:16 amBoris Red transitions are still MIA. Some of the generators are also not present when I select Boris Red Generator. How long will it be until Apple fixes Boris Red as a plugin to FCP? I purchased Red to cover some of the things lacking in FCP but now I can’t use it as a plugin. It does work as a standalone but it isn’t a plugin currently. It’s more like a crash the application device.
Doug Olin
Desert Vistas Multimedia -
Zack Hill
February 23, 2007 at 5:32 amcan you bypass 5.1.3 all together and go straight to 5.1.4?
jesus
zeechproductions.com -
Dave Sullivan
February 23, 2007 at 3:25 pmWell, Apple still haven’t solved the JVC HD-100 24/25 fps capture problems!!
In 25fps mode I still get slow responce to the controls in the capture window, captured footage is still broken up into smaller chunks, and I still get the odd ‘lost data’ dialogue box popping up.
I 24fps mode I’m unable to capture anything….and I’m not the only one!!Dave
Joe Murray
February 25, 2007 at 3:46 amI guess I’ll get to see if this fixed the reconnect problems I’ve been having since updating to 5.1.3 on Intel. I had a large project completely lose references to a couple dozen clips after we brought the project forward from a Power PC 5.1.2 setup.
Joe Murray
