Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.1.4 and HDCAM
  • FCP 5.1.4 and HDCAM
    Posted by Ron Humer on April 2, 2007 at 8:49 pm
    I have been experimenting with the Kona LHe and the Sony ADW-F500 for a long form job coming next week…. Let me prep that I’m new to HD but been editing since ’88. The smallest data rate I’ve gotten is using 8 bit uncompressed codec that’s standard to the mac. Is there a kona codec that is native to the board or is a better solution than what I’m using?
    The only codecs that come up are:
    aja kona 10bit- log rgb codec, aja kona 10bit rgb codec, aja kona 2vuy codec.
    Any assistance would be greatly appreciated.
    Ron
    Liam Stephens replied 19 years, 6 months ago 5 Members · 5 Replies
  • John Pale
    April 2, 2007 at 9:11 pm
    Use the AJA Kona DVCPRO HD Easy Setup appropriate for the flavor of HD your footage is in.
    The file size is smaller than uncompressed SD, you get lots of RT and great picture quality.
    Dont bother offlining at an SD resolution.
  • John Pale
    April 2, 2007 at 9:13 pm
    I should add that it doesn’t matter that you shot HDCAM…its perfectly okay to use DVCPRO HD as an editing codec.
  • Chi-ho Lee
    April 2, 2007 at 9:42 pm
    I agree with John. Unless if you need to make SD screener DVDs, then one advantage is to offline at DV quality since the compressing time would be less than using DVCPro HD.
    Chi-Ho Lee
    Film & Video Editor
    Apple Certified Final Cut Pro Trainer
    http://www.chiholee.com
  • Sean Lander
    April 2, 2007 at 11:58 pm
    Another endorsement for that codec. It is awesome. Not sure if the LHE can downconvert to SD, but that is definitely the way to go.
  • Liam Stephens
    April 3, 2007 at 1:31 am
    Our company just got a raid and the Kona LHe it works perfect, down converts to DVCPROHD no sweat. The kona comes with presets for FCP…
