FCP 5.1.4 and Boris Continuum?
Posted by Walter Biscardi on February 23, 2007 at 2:36 amApple has already released FCP 5.1.4. Does this fix any compatibility issues with Boris Continnum Complete on a Mac Intel?
We’re still running FCP 5.1.2.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Walter Biscardi replied 19 years, 7 months ago 4 Members · 6 Replies -
Peter Mcauley
February 23, 2007 at 1:40 pmHi Walter,
My understanding is that this release of FCP (5.1.4) does not change the way BCC operates within FCP (as compared to the 5.1.2 release.) There are still a couple of outstanding issues which are currently under investigation and hopefully will be resolved with the next major release of FCP.
I hope this helps.
Peter.
Walter Biscardi
February 23, 2007 at 1:53 pm[Peter McAuley] “My understanding is that this release of FCP (5.1.4) does not change the way BCC operates within FCP (as compared to the 5.1.2 release.)”
Well, I was referring more to the 5.1.3 release where Apple apparently broke the FX Plugs architecture within the app, hence 5.1.4.
So it’s “your understanding” or have you actually run FCP 5.1.4 with BCC 4 yet? I’ll be in a position in about 2 weeks to update to 5.1.4 if we have an all clear from Boris.
thanks for the info!
Tim Langston
February 23, 2007 at 2:30 pmBack with 5.1.2 Boris stated that in the next update of FCP Boris would again work. Now we’ve had 5.1.3 and 5.1.4 and Boris still does not work correctly? May I be so bold to ask, who’s not communicating, Apple or Boris? Does Apple need help from Boris or does Boris need help from Apple? Us editors would love to WOW our clients with RED and Contimuum but if I have to jump through hoops to get it to work, the product is gonna go unused, which is hurting me and hurting Boris.
We need some good news.
Tim
Tim Langston
Cryin’ Out Loud Productions
Fort Wayne, IN
http://www.colproductions.com -
Walter Biscardi
February 23, 2007 at 2:32 pm[Tim Langston] “May I be so bold to ask, who’s not communicating, Apple or Boris?”
Apple.
Apple broke the FX Plugs architecture when they released 5.1.3. All plug-ins using this architecture broke with FCP 5.1.3, for example I use Colorista from Red Giant, and that did not work with FCP 5.1.3.
So Apple released 5.1.4 within a week and I’m just checking to see if it did, indeed, fix the FX Plugs before I update. We left all our systems at 5.1.2 after seeing the plethora of posts pop up with 5.1.3 issues.
Harley Michailuck
February 23, 2007 at 2:34 pm[walter biscardi] “So it’s “your understanding” or have you actually run FCP 5.1.4 with BCC 4 yet? I’ll be in a position in about 2 weeks to update to 5.1.4 if we have an all clear from Boris.”
Running with it right now… if you follow the install instructions at the Boris website you should have no problem. I’ve been running BCC 4 and RED 4.1 with FCP 5.1.2 – 5.1.3 – and now 5.1.4 with no problems. The BCC4 Transitions are however still broken.
Best,
HarleyHarley Michailuck
Brass Orchid Post fx
Saskatoon, SK Canada -
Walter Biscardi
February 23, 2007 at 2:49 pm[Harley Michailuck] “Running with it right now… if you follow the install instructions at the Boris website you should have no problem”
Thanks, we’ll update to FCP 5.1.4 in a few weeks.
