Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.1.2 maximizing RAM usage
Posted by Phil Muri on October 1, 2006 at 12:28 amHowdy Cowpokes,
My MP has 5 GBs of RAM and System Profiler confirms that all is OK with all the modules
James Reid replied 19 years, 12 months ago 3 Members · 4 Replies -
David Roth weiss
October 1, 2006 at 2:12 amPhil,
At this point FCP is only capable of using 2.5gb RAM maximum. The next generation 64-bit version of FCP will be able to utilize a lot more.
DRW
Phil Muri
October 1, 2006 at 3:04 amThanks for your reply, David.
Can I then max out all the memory settings to 100%
David Roth weiss
October 1, 2006 at 5:14 pm[pseudojag] “Can I then max out all the memory settings to 100%
James Reid
October 4, 2006 at 5:33 pmThis Apple doc explains why:
Maximum memory usage in Final Cut Pro is 2.5 GBhttps://docs.info.apple.com/article.html?artnum=93844
