Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.1.1 “Rosetta” on MacBook Pro Short Term Fix?
  • FCP 5.1.1 “Rosetta” on MacBook Pro Short Term Fix?
    Posted by Joe Langenfeld on June 28, 2006 at 4:13 pm
    Has anyone figured out how to install the PPC FCP 5.1.1 (Rosetta), NOT Universal, on the Intel Macs?
    I have had a MacBook Pro 15″ since March, running UNIVERSAL FCP 5.1.1, and I have not been able to use it for FCP editing, mainly because I cannot edit without certain plug-ins, filters, and WMV’s which are not supported in the Universal version of FCP 5.1.1.
    However, if I could install the PPC version of FCP 5.1.1 as a “Rosetta” version, it would run a lot slower, but it would support the plugins and other non-supported items, and I could use this expensive laptop without having to buy a G4 Powerbook!
    Eventually, Universal support will come out for this stuff, but it’s been 4 months now!
    Joe
    Bret Williams replied 20 years, 3 months ago 6 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    June 28, 2006 at 5:13 pm
    [Joe Langenfeld] “I have had a MacBook Pro 15″ since March, running UNIVERSAL FCP 5.1.1, and I have not been able to use it for FCP editing, mainly because I cannot edit without certain plug-ins, filters, and WMV’s which are not supported in the Universal version of FCP 5.1.1.”
    I’m pretty sure Flip 4 Mac works on the Universal machines so that should take care of your WMV’s. As for the plug-ins, which ones are you trying to use? I’m running my copy of Boris Continuum Complete 3.0.5 which is almost two years old with FCP 5.1.1 Universal.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Bret Williams
    June 28, 2006 at 5:20 pm
    There is no such thing. The last PPC version is 5.0.4. 5.1.x is the jump to universal. You could try installing 5.0.x and see if it runs under rosetta emulation, but I’m guessing it would be ususeable or reject it.
  • Tom Wolsky
    June 28, 2006 at 5:40 pm
    There is a PPC installer on 5.1 disc, but it’s for use on PPC machines only. It can’t be forced to run on an Intel machine AFAIK.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • John Pale
    June 28, 2006 at 5:46 pm
    In Finder, select the application icon and Get Info (apple-I)
    Is there a checkbox to force it to run in Rosetta (not on an Intel Machine, but I have heard some Universal Apps have this)
  • Joe Langenfeld
    June 28, 2006 at 9:49 pm
    Thanks, I will try to install FCP in Rosetta using Get Info.
    And no, Walter, flip4mac does not work on MacTel, yet. (they have announced a beta version).
    Will these software gaps be fixed by the time the G5 replacement is announced?
  • Joe Langenfeld
    June 28, 2006 at 10:02 pm
    I tried checking the “Open using Rossetta” in the Get Ino folder of FCP 5.1.1. I think it launched OK, (because it was slow!) but the plug-ins & filters that I was hoping to use (installed in the plug-in folder) still were not available.
    The ones I tried were DFT 55mm, DFT Composite Suite, DFT Zmatte, a demo of Magic Bullet, and a Sapphire demo. (I have a beta trial of Sapphire for Universal that loads). Maybe I will try to re-install them.
    Back before Universal, (5.0) these plug-ins loaded and worked fine.
  • Sean Oneil
    June 29, 2006 at 12:35 am
    [Joe Langenfeld] “Will these software gaps be fixed by the time the G5 replacement is announced”
    Probably. This is the reason why they released Intels for iMacs first, then laptops, and saved desktops for last.
  • Bret Williams
    June 29, 2006 at 3:08 pm
    And because there still isn’t a replacement processor out yet for the G5 quad, since the current Core duo, etcs don’t run in Quad formation, they would be about the same or slower than a quad G5. Yes, they’d beat the dual G5s, but the whole thing would be a messy lineup.
