Activity Forums Apple Final Cut Pro Legacy FCP 5.1.1 and 5.1.2 crashes while exporting sequence as Quicktime
  • FCP 5.1.1 and 5.1.2 crashes while exporting sequence as Quicktime
    Posted by Shawn Marshall on September 27, 2006 at 11:04 pm
    Greetings:
    FCP 5.1.1 and 5.1.2 crashes when I attempt to export some sequences in my project as a Quicktime.
    I opened up a 4.5 project in 5.1.1 to make some updates to our motion graphics demo reels. The clips and sequences are compressed with the Aurora Motion JPEGA through their IgniterX PCI card. I’ve never had problems with this setup in the past.
    On one two-minute sequence (1 video track with cuts and a few dissolves, no plugins used, stereo audio track) I select Export-Quicktime. The Save dialog comes up. I have the Setting: Current, Include: Audio and Video, and Markers: None. I do not have Make Movie Self-Contained selected. The movie starts exporting; the progress bar reaches around 20% after around 45 seconds, then FCP disappears and the alert box “The application Final Cut Pro quit unexpectedly.” appears.
    If I do the same thing but enable “Make Movie Self-Contained” the progress bar gets to around 23%, then quits. If I select “Make Movie Self-Contained” and “Recompress all frames” the sequence will export. If I export Using Quicktime Conversion to the animation codec it will export.
    I updated to 5.1.2 hoping that would solve the problem, but it didn’t.
    I’ve repaired permissions and trashed the preferences several times. I also removed the Avid codecs, but to no avail.
    Any suggestions? I’m thinking I should just go back to FCP 4.5 (though I had to send that disc in for the upgrade; I made a copy). That would probably hold me until I get an Intel Mac Pro next year sometime (once all of the Adobe stuff and Lightwave goes UB).
    I’ve also posted this in the Apple FCP discussions, but have received no replies.
    Thanks.
    Shawn Marshall
    Marshall Arts Motion Graphics
    Here’s the crash info I’m getting:
    Date/Time: 2006-09-26 21:08:52.515 -0700
    OS Version: 10.4.7 (Build 8J135)
    Report Version: 4
    Command: Final Cut Pro
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Parent: WindowServer [78]
    Version: 5.1.2 (5.1.2)
    Build Version: 3
    Project Name: FCPApp
    Source Version: 609211640
    PID: 279
    Thread: 0
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_INVALID_ADDRESS (0x0001) at 0x33460000
    Thread 0 Crashed:
    0 <<00000000>> 0xffff86bc __bzero + 188 (cpu_capabilities.h:187)
    1 KGCore 0x00ace9b4 KGMemoryFill + 36
    2 …alCutPro.Plugins.QTM Reader 0x062cd288 PluginStart + 5312
    3 …alCutPro.Plugins.QTM Reader 0x062ec9b4 AudioExtractor::~AudioExtractor [in-charge deleting]() + 22904
    4 …alCutPro.Plugins.QTM Reader 0x062f18cc PluginMainEntry(long, long, KGDictInt*, void*) + 6356
    5 com.apple.FinalCutPro 0x00240050 ExportClipCore(KGDictInt*, long, KGDictInt*, KGDictInt*, KGFileSpec*, long) + 2896
    6 com.apple.FinalCutPro 0x002461b0 pKGExportClip(KGDictInt*, long) + 840
    7 com.apple.FinalCutPro 0x001b4a70 pKGMenuPerformExport(KGDictInt*, long) + 128
    8 com.apple.FinalCutPro 0x000ad8a4 pKGClipHandleDefaultMenu(KGDictInt*, long, unsigned char) + 1040
    9 com.apple.FinalCutPro 0x001e1034 pKGClipDefaultMessage(long, long, KGDictInt*, KGDictInt*, long) + 972
    10 …Pro.Plugins.Timeline Editor 0x06353030 DisposeMenuStrings() + 40288
    11 com.apple.FinalCutPro 0x002b7fa8 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 2088
    12 com.apple.FinalCutPro 0x0025e05c ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 120
    13 com.apple.FinalCutPro 0x0025f94c TimelineMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 84
    14 com.apple.FinalCutPro 0x002ace68 pKGPanelWindowProc(long, long, KGDictInt*, void*) + 96
    15 com.apple.FinalCutPro 0x002c48f0 pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 140
    16 com.apple.FinalCutPro 0x00155d18 HandleMenuCommand(long, unsigned char, unsigned char, unsigned char, KGErrorCode (*)(long, long, KGDictInt*, void*), void*) + 460
    17 com.apple.FinalCutPro 0x00155e90 HandleCommand(long, unsigned char, unsigned char, unsigned char) + 236
    18 com.apple.FinalCutPro 0x00402144 CommandProcess(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 308
    19 com.apple.HIToolbox 0x931e5554 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 692
    20 com.apple.HIToolbox 0x931e4cac SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
    21 com.apple.HIToolbox 0x931eba60 SendEventToEventTarget + 40
    22 com.apple.HIToolbox 0x932642cc SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 380
    23 com.apple.HIToolbox 0x93294158 SendMenuItemSelectedEvent + 136
    24 com.apple.HIToolbox 0x93294060 FinishMenuSelection(MenuData*, MenuData*, MenuResult*, MenuResult*, unsigned long, unsigned long, unsigned long, unsigned char) + 144
    25 com.apple.HIToolbox 0x9327b56c MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 404
    26 com.apple.HIToolbox 0x9327b054 MenuSelect + 100
    27 com.apple.HIToolbox 0x933de8a4 HandleMouseEvent(OpaqueEventRef*) + 84
    28 com.apple.HIToolbox 0x9327afdc StandardMenuBarEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 56
    29 com.apple.HIToolbox 0x931e5554 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 692
    30 com.apple.HIToolbox 0x931e4cac SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
    31 com.apple.HIToolbox 0x931eba60 SendEventToEventTarget + 40
    32 com.apple.HIToolbox 0x932772d4 HandleMouseEvent(OpaqueEventRef*) + 388
    33 com.apple.HIToolbox 0x931ebdcc ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 496
    34 com.apple.HIToolbox 0x931e57a4 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1284
    35 com.apple.HIToolbox 0x931e4cac SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
    36 com.apple.HIToolbox 0x931eba60 SendEventToEventTarget + 40
    37 com.apple.HIToolbox 0x9322c7a0 ToolboxEventDispatcher + 92
    38 com.apple.HIToolbox 0x9322c72c HLTBEventDispatcher + 16
    39 com.apple.HIToolbox 0x9322ace4 RunApplicationEventLoop + 148
    40 com.apple.FinalCutPro 0x001593b8 KGMainEvent(void*) + 52
    41 com.apple.FinalCutPro 0x002c90c4 main + 64
    42 com.apple.FinalCutPro 0x00002b94 _start + 340
    43 com.apple.FinalCutPro 0x00002a3c start + 60
    Thread 1:
    0 libSystem.B.dylib 0x9002c2e8 semaphore_wait_signal_trap + 8
    1 libSystem.B.dylib 0x90030dcc pthread_cond_wait + 480
    2 com.apple.FinalCutPro 0x00427e30 Synchronizable::Wait() + 48
    3 com.apple.FinalCutPro 0x00413e38 DisplayQueue::Run() + 724
    4 com.apple.FinalCutPro 0x00450f34 Thread::RunHelper(void*) + 32
    5 libSystem.B.dylib 0x9002bc28 _pthread_body + 96
    Thread 2:
    3 com.apple.FinalCutPro 0x004c8bb8 WorkUnitPerformer::Run() + 72
    Thread 3:
    0 libSystem.B.dylib 0x9000b268 mach_msg_trap + 8
    1 libSystem.B.dylib 0x9000b1bc mach_msg + 60
    2 com.apple.CoreFoundation 0x907dbb78 __CFRunLoopRun + 832
    3 com.apple.CoreFoundation 0x907db47c CFRunLoopRunSpecific + 268
    4 com.apple.CoreFoundation 0x907ea8dc CFRunLoopRun + 52
    5 com.apple.DVCPROHDMuxer 0x0df606d4 AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 392
    6 libSystem.B.dylib 0x9002bc28 _pthread_body + 96
    Thread 4:
    5 com.apple.ProIOMuxer 0x0e63337c APW::PTA::IsochronousThread::Start(APW::PTA::IsochronousThread*) + 576
    Thread 5:
    5 com.apple.AVCVideoServices 0x00c27294 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 168
    Thread 6:
    4 com.apple.audio.CoreAudio 0x9145163c HALRunLoop::OwnThread(void*) + 264
    5 com.apple.audio.CoreAudio 0x914513dc CAPThread::Entry(CAPThread*) + 96
    Thread 7:
    0 libSystem.B.dylib 0x900551a8 semaphore_timedwait_signal_trap + 8
    1 libSystem.B.dylib 0x90071828 pthread_cond_timedwait_relative_np + 556
    2 …ple.CoreServices.CarbonCore 0x90bf4550 TSWaitOnSemaphoreCommon + 176
    3 …ickTimeComponents.component 0x98b9f7c4 ReadSchedulerThreadEntryPoint + 5300
    4 libSystem.B.dylib 0x9002bc28 _pthread_body + 96
    Thread 8:
    3 …ple.CoreServices.CarbonCore 0x90bfeff8 AIOFileThread(void*) + 520
    Thread 9:
    2 com.apple.vImage 0x91d7a1ac vImageQueue_DequeueJob + 60
    3 com.apple.vImage 0x91d7a538 vImageWorkerThreadFunc + 120
    Thread 10:
    0 libSystem.B.dylib 0x9002efac kevent + 12
    1 com.apple.DesktopServices 0x92854250 TFSNotificationTask::FSNotificationTaskProc(void*) + 56
    2 …ple.CoreServices.CarbonCore 0x90bc1900 PrivateMPEntryPoint + 76
    3 libSystem.B.dylib 0x9002bc28 _pthread_body + 96
    Thread 11:
    2 …ple.CoreServices.CarbonCore 0x90bc1af0 MPWaitOnQueue + 224
    3 com.apple.DesktopServices 0x928548cc TNodeSyncTask::SyncTaskProc(void*) + 116
    4 …ple.CoreServices.CarbonCore 0x90bc1900 PrivateMPEntryPoint + 76
    Thread 0 crashed with PPC Thread State 64:
    srr0: 0x00000000ffff86bc srr1: 0x100000000200f030 vrsave: 0x0000000000000000
    cr: 0x4402221d xer: 0x0000000000000000 lr: 0x0000000000ace9b4 ctr: 0x0000000001ffe9ac
    r0: 0x0000000000000000 r1: 0x00000000bfff8570 r2: 0x00000000333ad610 r3: 0x00000000333ad663
    r4: 0x0000000000000062 r5: 0x000000000000001d r6: 0xffffffffffffffff r7: 0x0000000000000000
    r8: 0x0000000001ffffff r9: 0x0000000033460000 r10: 0x0000000000000001 r11: 0x0000000000ad20a0
    r12: 0x0000000090129e60 r13: 0x0000000000e30516 r14: 0x0000000000000000 r15: 0x0000000000000000
    r16: 0x0000000033499378 r17: 0x0000000007d513bc r18: 0x00000000334c0598 r19: 0x0000000000000026
    r20: 0x0000000000000001 r21: 0x0000000000020004 r22: 0x0000000000000000 r23: 0x0000000000000000
    r24: 0x0000000000000000 r25: 0x000000003697cba0 r26: 0x0000000000000006 r27: 0x00000000019e66d4
    r28: 0x0000000000000001 r29: 0x00000000019e673c r30: 0x00000000334c437c r31: 0x00000000062e800c
    Binary Images Description:
    0x1000 – 0x6c0fff com.apple.FinalCutPro 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    0xa47000 – 0xa4efff com.apple.proapps.ProTimecode 1.0 /Applications/Final Cut Pro.app/Contents/Frameworks/ProTimecode.framework/Versions/A/ProTimecode
    0xa55000 – 0xa9cfff com.apple.proapps.MIO 1.0 /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
    0xacc000 – 0xad1fff KGCore /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
    0xad7000 – 0xaeefff com.apple.AERegistration 1.2 (58.2) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0xc05000 – 0xc0dfff com.apple.AEProfiling 1.2 (14.2) /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0xc15000 – 0xc39fff com.apple.AVCVideoServices 1.0 (32) /Applications/Final Cut Pro.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
    0xc52000 – 0xc65fff com.apple.framework.promedia.ProMediaIOUnit 1.0.0 (1) /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIOUnit.framework/Versions/A/ProMediaIOUnit
    0xc72000 – 0xc7cfff com.apple.framework.promediaio 1.0.0 (1) /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIO.framework/Versions/A/ProMediaIO
    0xc82000 – 0xcf6fff com.apple.ProFX 1.1 /Library/Frameworks/ProFX.framework/Versions/A/ProFX
    0x19e8000 – 0x19ecfff com.apple.FinalCutPro.Plugins.AudioGroupsExport 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
    0x19ef000 – 0x19f5fff com.apple.FinalCutPro.Plugins.Cache Manager 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
    0x1afd000 – 0x1b2afff com.apple.FinalCutPro.Plugins.AfterEffects 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
    0x1b31000 – 0x1b4afff com.apple.FinalCutPro.Plugins.AudioMixer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
    0x1b56000 – 0x1b6cfff com.apple.proapps.ControlSurfaceSupport 2.0 (54) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
    0x1b82000 – 0x1c28fff com.apple.FinalCutPro.Plugins.Browser 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
    0x1c3d000 – 0x1c5afff com.apple.FinalCutPro.CinemaTools 3.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
    0x1c63000 – 0x1c6ffff com.apple.FinalCutPro.Plugins.CTHelper 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
    0x1c74000 – 0x1c9afff com.apple.FinalCutPro.Plugins.EditTape 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
    0x1ca7000 – 0x1cf1fff com.apple.FinalCutPro.Plugins.EDL Export 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
    0x1d05000 – 0x1d0dfff com.apple.FinalCutPro.Plugins.Effect Builder 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
    0x1d10000 – 0x1d1cfff com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
    0x1d22000 – 0x1d54fff com.apple.FinalCutPro.Plugins.FCS Engine 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
    0x1d5b000 – 0x1d6cfff com.apple.FinalCutPro.Plugins.FilterCustomEd 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
    0x1d6f000 – 0x1d83fff com.apple.FinalCutPro.Plugins.FilterViewer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
    0x1d86000 – 0x1da6fff com.apple.FinalCutPro.Plugins.Flash 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
    0x1db5000 – 0x1dc1fff com.apple.FinalCutPro.Plugins.GenViewer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
    0x1dc4000 – 0x1dc9fff com.apple.FinalCutPro.Plugins.LayerFileReader 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
    0x1dcc000 – 0x1dd1fff com.apple.FinalCutPro.Plugins.MolokiniSupport 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
    0x1dd5000 – 0x1de8fff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
    0x1df4000 – 0x1df9fff com.apple.FinalCutPro.Plugins.NuggetExport 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
    0x1f05000 – 0x1f4ffff com.apple.FinalCutPro.Plugins.Media Manager 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
    0x1f5a000 – 0x1f6efff com.apple.FinalCutPro.Plugins.Motion Viewer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
    0x1f71000 – 0x1f8ffff com.apple.FinalCutPro.Plugins.Movie Analyzer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
    0x1f9c000 – 0x1fabfff com.apple.FinalCutPro.Plugins.Movie Viewer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0x1fae000 – 0x1fb8fff com.apple.FinalCutPro.Plugins.Perf Analyzer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
    0x1fbb000 – 0x1fcefff com.apple.FinalCutPro.Plugins.ProAppsIntegration 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
    0x1fdb000 – 0x1fe9fff com.apple.FinalCutPro.Plugins.Pulldown Support 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
    0x1fef000 – 0x1ff8fff com.apple.FinalCutPro.Plugins.QuickView 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
    0x1ffb000 – 0x1ffdfff com.apple.FinalCutPro.Plugins.Text Window 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
    0x60e6000 – 0x60f4fff com.apple.FinalCutPro.Plugins.Relink Media 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
    0x6205000 – 0x62adfff com.apple.FinalCutPro.Plugins.OMF Audio Export 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
    0x62c9000 – 0x6304fff com.apple.FinalCutPro.Plugins.QTM Reader 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
    0x6310000 – 0x6385fff com.apple.FinalCutPro.Plugins.Timeline Editor 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
    0x638d000 – 0x6395fff com.apple.FinalCutPro.Plugins.Transcoder 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
    0x6399000 – 0x63aafff com.apple.FinalCutPro.Plugins.Transition Viewer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
    0x63ad000 – 0x63c3fff com.apple.FinalCutPro.Plugins.Trimming 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
    0x63c6000 – 0x63cefff com.apple.FinalCutPro.Plugins.VDUSupport 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
    0x63d2000 – 0x6414fff com.apple.FinalCutPro.Plugins.Vector Accelerator 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
    0x6418000 – 0x642afff com.apple.FinalCutPro.Plugins.VideoLog 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
    0x642d000 – 0x6446fff com.apple.FinalCutPro.Plugins.VoiceOver 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
    0x644a000 – 0x64a7fff com.apple.FinalCutPro.Plugins.XML Support 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
    0x7332000 – 0x734bfff GLDriver /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver
    0x7351000 – 0x736cfff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x73e7000 – 0x7427fff com.auroravideosystems.igniter.component ??? (6.4.4) /Library/QuickTime/Aurora Igniter.component/Contents/MacOS/Aurora Igniter
    0x742f000 – 0x7434fff com.apple.LiveType.component 2.1.2 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x7438000 – 0x749dfff com.apple.LiveType.framework 2.1.2 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
    0x74c7000 – 0x752ffff com.DivXInc.DivXDecoder 6.2.5 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0x753c000 – 0x7540fff com.apple.motion.component 1.0 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    0x761d000 – 0x7634fff com.apple.fcp.DVOutputUnit 1.3 /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
    0x77e5000 – 0x78f4fff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0x7923000 – 0x7a13fff com.apple.ATIRadeon9700GLDriver 1.4.18 (4.1.8) /System/Library/Extensions/ATIRadeon9700GLDriver.bundle/Contents/MacOS/ATIRadeon9700GLDriver
    0x7a3f000 – 0x7a53fff com.apple.IMXCodec 1.2 (140) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0x7ae7000 – 0x7afdfff com.apple.FCP Uncompressed 422.component 1.4 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0x7b02000 – 0x7b34fff com.apple.DVCPROHDCodec 1.3 (228) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0x7b7e000 – 0x7bcbfff com.apple.AppleHDVCodec 1.2 (206) /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0x7bd4000 – 0x7beefff com.apple.AppleIntermediateCodec 1.1 (141) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0x7bf3000 – 0x7c6cfff com.apple.applepixletvideo 1.2.5 (1.2d5) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0x7e12000 – 0x7e4ffff com.apple.soundtrackpro.integration 1.0.1 /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
    0x7e64000 – 0x7e78fff com.apple.motion.MotionBundle 2.1 /Library/Application Support/ProApps/Bundles/Motion.bundle/Contents/MacOS/Motion
    0x887d000 – 0x8ff6fff com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
    0x9f89000 – 0x9f95fff com.apple.QuartzComposer.FxPlugWrapper 1.0 /Library/Application Support/ProApps/Internal Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
    0x9f9d000 – 0x9fa9fff com.apple.PluginManager 1.6 (28) /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
    0x9ffb000 – 0x9ffcfff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
    0xa105000 – 0xa87cfff com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
    0xb2ce000 – 0xba43fff com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
    0xc882000 – 0xc893fff com.apple.fxplugframework 1.1 /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
    0xca05000 – 0xd17efff com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
    0xddfb000 – 0xddfcfff com.apple.ProIOVideoOutputClock 2.0.1 /Library/QuickTime/ProIOVideoOutputClock.component/Contents/MacOS/ProIOVideoOutputClock
    0xdf4a000 – 0xdfacfff com.apple.DVCPROHDMuxer 1.2 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0xe105000 – 0xe17dfff com.apple.DVCPROHDAudio 1.2 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0xe305000 – 0xe383fff com.apple.ProIOAudio 2.0.1 /Library/Audio/Plug-Ins/HAL/ProIOAudio.plugin/Contents/MacOS/ProIOAudio
    0xe505000 – 0xe5defff com.apple.motion.filters 2.1.2 /Library/Application Support/ProApps/Internal Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
    0xe630000 – 0xe671fff com.apple.ProIOMuxer 2.0.1 /Library/QuickTime/ProIOMuxer.component/Contents/MacOS/ProIOMuxer
    0xe69e000 – 0xe6b8fff com.apple.IOFireWireLib 2.2.5 /System/Library/Extensions/IOFireWireFamily.kext/Contents/PlugIns/IOFireWireLib.plugin/Contents/MacOS/IOFireWireLib
    0xe6de000 – 0xe729fff com.apple.audio.CoreAudio.ProMediaIOAVSAVCPlugIn 7.0 /Applications/Final Cut Pro.app/Contents/PlugIns/ProMediaIOAVSAVC.plugin/Contents/MacOS/ProMediaIOAVSAVC
    0xe78b000 – 0xe798fff com.apple.fcp.TundraOutputUnit 1.3 /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
    0xf024000 – 0xf046fff com.apple.ProIOVideoOutput 2.0.1 /Library/QuickTime/ProIOVideoOutput.component/Contents/MacOS/ProIOVideoOutput
    0xf059000 – 0xf092fff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0xf098000 – 0xf0d7fff com.apple.QuickTimeFireWireDV.component 7.1.3 /System/Library/QuickTime/QuickTimeFirewireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0xf0e2000 – 0xf0f1fff com.apple.DVCPROHDVideoOutput 1.2 /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0xf205000 – 0xf20dfff com.apple.DesktopVideoOut 1.2.4 /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0xf211000 – 0xf21bfff com.apple.IOFWDVComponents 1.7.9 /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0xf22c000 – 0xf238fff com.apple.compressor.MediaServerAPI 2.3 /Library/Frameworks/MediaServerAPI.framework/MediaServerAPI
    0xf245000 – 0xf246fff com.apple.compressor.stomp 2.3 /Library/Frameworks/Compressor.framework/Compressor
    0xf249000 – 0xf277fff com.apple.compressor.ImageProcessing 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
    0xf29f000 – 0xf2a9fff com.apple.compressor.StompUtil 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
    0xf2b4000 – 0xf2bbfff com.apple.compressor.FilterUI 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
    0xf2c2000 – 0xf2c4fff com.apple.qmaster.swamp 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
    0xf2c7000 – 0xf2d3fff com.apple.qmaster.SwampUtil 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
    0xf2e1000 – 0xf2ebfff com.apple.qmaster.SwampService 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
    0xf2fa000 – 0xf2fcfff com.apple.Helium 2.0.5 /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
    0xf405000 – 0xf4a2fff com.apple.AECore 2.3 /Library/Frameworks/AECore.framework/Versions/A/AECore
    0xf52d000 – 0xf5dcfff com.apple.compressor.StompTypes 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
    0xf64b000 – 0xf71cfff com.apple.compressor.transcoding 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
    0xf806000 – 0xf839fff com.apple.compressor.StompUI 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
    0xf859000 – 0xf888fff com.apple.qmaster.SwampCore 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
    0xf8b8000 – 0xf8e8fff com.apple.qmaster.SwampTypes 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
    0xf91e000 – 0xf96ffff com.apple.qmaster.do 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0xf9c6000 – 0xf9d4fff com.apple.qmaster.Status 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
    0xf9ec000 – 0xf9f5fff com.apple.qmaster.RequestProcessing 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
    0xfa06000 – 0xfa14fff com.apple.qmaster.ServiceControl 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
    0xfa2a000 – 0xfa5dfff com.apple.qmaster.ContentControl 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
    0xfa8d000 – 0xfb32fff com.apple.qmaster.JobControl 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
    0xfbce000 – 0xfbdcfff com.apple.qmaster.ClusterManager 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
    0xfbee000 – 0xfc09fff com.apple.qmaster.SwampUI 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
    0xfc21000 – 0xfc2dfff com.apple.qmaster.SwampExecutor 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
    0x10000000 – 0x1005bfff com.apple.proapps.AudioMixEngine 2.0 (54) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x338ee000 – 0x338f2fff com.apple.iokit.IOQTComponents 1.4 /System/Library/Components/IOQTComponents.component/Contents/MacOS/IOQTComponents
    0x338f6000 – 0x338fcfff com.apple.ATIRadeon9700GA 1.4.18 (4.1.8) /System/Library/Extensions/ATIRadeon9700GA.plugin/Contents/MacOS/ATIRadeon9700GA
    0x35079000 – 0x3508bfff com.apple.ProIOVideoOutputCodec 2.0.1 /Library/QuickTime/ProIOVideoOutputCodec.component/Contents/MacOS/ProIOVideoOutputCodec
    0x35405000 – 0x355fefff net.telestream.wmv.import 2.1.0.33 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0x70000000 – 0x700fcfff com.apple.audio.units.Components 1.4.3 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0x8fe00000 – 0x8fe52fff dyld 45.1 /usr/lib/dyld
    0x90000000 – 0x901bbfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
    0x90213000 – 0x90218fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
    0x9021a000 – 0x90267fff com.apple.CoreText 1.0.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x90292000 – 0x90343fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x90372000 – 0x9072cfff com.apple.CoreGraphics 1.258.33 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x907b9000 – 0x90892fff com.apple.CoreFoundation 6.4.6 (368.27) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x908db000 – 0x908dbfff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x908dd000 – 0x909dffff libicucore.A.dylib /usr/lib/libicucore.A.dylib
    0x90a39000 – 0x90abdfff libobjc.A.dylib /usr/lib/libobjc.A.dylib
    0x90ae7000 – 0x90b57fff IOKit /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x90b6d000 – 0x90b7ffff libauto.dylib /usr/lib/libauto.dylib
    0x90b86000 – 0x90e5dfff com.apple.CoreServices.CarbonCore 681.4 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x90ec3000 – 0x90f43fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x90f8d000 – 0x90fcefff com.apple.CFNetwork 129.16 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x90fe3000 – 0x90ffbfff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
    0x9100b000 – 0x9108cfff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x910d2000 – 0x910fbfff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x9110c000 – 0x9111afff libz.1.dylib /usr/lib/libz.1.dylib
    0x9111d000 – 0x912d7fff com.apple.security 4.4 (27566) /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x913d5000 – 0x913defff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x913e5000 – 0x9140dfff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x91420000 – 0x9142bfff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
    0x91430000 – 0x91438fff libbsm.dylib /usr/lib/libbsm.dylib
    0x9143c000 – 0x914b7fff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x914f4000 – 0x914f4fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x914f6000 – 0x9152efff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x91549000 – 0x91616fff com.apple.ColorSync 4.4.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x9166b000 – 0x916fcfff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x91743000 – 0x917fafff com.apple.QD 3.10.20 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x91837000 – 0x91895fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x918c4000 – 0x918e5fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x918f9000 – 0x9191efff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
    0x91931000 – 0x91973fff com.apple.LaunchServices 180 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x9198f000 – 0x919a3fff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x919b1000 – 0x919f1fff com.apple.ImageIO.framework 1.4.7 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x91a07000 – 0x91acffff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
    0x91b1d000 – 0x91b32fff libcups.2.dylib /usr/lib/libcups.2.dylib
    0x91b37000 – 0x91b54fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x91b59000 – 0x91bc8fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x91bdf000 – 0x91be3fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x91be5000 – 0x91c2dfff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
    0x91c32000 – 0x91c6ffff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x91c76000 – 0x91c8ffff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x91c94000 – 0x91c97fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x91c99000 – 0x91c99fff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x91c9b000 – 0x91d80fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x91d88000 – 0x91da7fff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x91e13000 – 0x91e81fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x91e8c000 – 0x91f21fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x91f3b000 – 0x924c3fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x924f6000 – 0x92821fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x92851000 – 0x928d9fff com.apple.DesktopServices 1.3.4 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x9291a000 – 0x92b45fff com.apple.Foundation 6.4.6 (567.27) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x92c63000 – 0x92d41fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
    0x92d61000 – 0x92e4ffff libiconv.2.dylib /usr/lib/libiconv.2.dylib
    0x92e61000 – 0x92e7ffff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x92e8a000 – 0x92ee4fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x92f02000 – 0x92f02fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x92f04000 – 0x92f18fff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x92f30000 – 0x92f40fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x92f4c000 – 0x92f61fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x92f73000 – 0x92ffafff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x9300e000 – 0x93019fff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x93023000 – 0x93050fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x9306a000 – 0x93079fff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x93085000 – 0x930ebfff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x9311c000 – 0x9316bfff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x93199000 – 0x931b6fff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x931c8000 – 0x931d5fff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x931de000 – 0x934ebfff com.apple.HIToolbox 1.4.8 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x9363a000 – 0x93646fff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x9364b000 – 0x9366bfff com.apple.DirectoryService.Framework 3.1 /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x93683000 – 0x936b3fff com.apple.MediaKit 8.6.2 (345.1.8) /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x936be000 – 0x936befff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x936c0000 – 0x93cf3fff com.apple.AppKit 6.4.7 (824.41) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x94080000 – 0x940f0fff com.apple.CoreData 80 /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x94129000 – 0x941ecfff com.apple.audio.toolbox.AudioToolbox 1.4.3 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x9423e000 – 0x9423efff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x94240000 – 0x943f3fff com.apple.QuartzCore 1.4.8 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x94446000 – 0x94483fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
    0x9448b000 – 0x944dbfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x9451b000 – 0x9455ffff com.apple.bom 8.4 (86.2) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x9456b000 – 0x945a3fff com.apple.vmutils 4.0.0 (85) /System/Library/PrivateFrameworks/vmutils.framework/vmutils
    0x9467e000 – 0x9468dfff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
    0x94695000 – 0x946a2fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x946e8000 – 0x94701fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x94708000 – 0x949d7fff com.apple.QuickTime 7.1.3 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x94a9a000 – 0x94b0bfff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
    0x94b7e000 – 0x94b9ffff libmx.A.dylib /usr/lib/libmx.A.dylib
    0x94ca7000 – 0x94dd7fff com.apple.AddressBook.framework 4.0.4 (485.1) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x94e69000 – 0x94e78fff com.apple.DSObjCWrappers.Framework 1.1 /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x94e80000 – 0x94eadfff com.apple.LDAPFramework 1.4.1 (69.0.1) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x94eb4000 – 0x94ec4fff libsasl2.2.dylib /usr/lib/libsasl2.2.dylib
    0x94ec8000 – 0x94ef7fff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
    0x94f07000 – 0x94f24fff libresolv.9.dylib /usr/lib/libresolv.9.dylib
    0x9531c000 – 0x9531cfff com.apple.DiscRecording 3.1.3 (???) /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x9531e000 – 0x953a1fff com.apple.DiscRecordingEngine 3.1.3 /System/Library/Frameworks/DiscRecording.framework/Versions/A/Frameworks/DiscRecordingEngine.framework/Versions/A/DiscRecordingEngine
    0x953ce000 – 0x95414fff com.apple.DiscRecordingContent 3.1.3 /System/Library/Frameworks/DiscRecording.framework/Versions/A/Frameworks/DiscRecordingContent.framework/Versions/A/DiscRecordingContent
    0x95612000 – 0x9563afff libcurl.3.dylib /usr/lib/libcurl.3.dylib
    0x95e4c000 – 0x95e8bfff com.apple.QTKit 7.1.3 /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x95ee8000 – 0x95f1afff com.apple.PDFKit 1.0.1 /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x96253000 – 0x96325fff com.apple.prokit 3.1 (589) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    0x96ab4000 – 0x96af3fff com.apple.audio.midi.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x96ebb000 – 0x96edafff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x975f1000 – 0x976b2fff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x976dd000 – 0x976defff libGLSystem.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib
    0x976e0000 – 0x976edfff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x977ee000 – 0x97809fff com.apple.AppleVAFramework 2.4.25 /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x98210000 – 0x982e1fff com.apple.QuartzComposer 1.2.3 (32.21) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x9835e000 – 0x9835efff com.apple.quartzframework 1.0 /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x9870c000 – 0x9881afff com.apple.DiskImagesFramework 10.4.7 (114.1) /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x98898000 – 0x988a5fff libbz2.1.0.dylib /usr/lib/libbz2.1.0.dylib
    0x98b88000 – 0x9953ffff com.apple.QuickTimeComponents.component 7.1.3 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x99766000 – 0x9976afff com.apple.QuickTimeH264.component 7.1.3 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x9976c000 – 0x99850fff QuickTimeH264.altivec /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.altivec
    0x9999c000 – 0x99a63fff com.apple.QuickTimeMPEG4.component 7.1.3 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x9a419000 – 0x9a41afff com.apple.iokit.dvcomponentglue 1.7.9 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0x9a427000 – 0x9a46bfff com.apple.viceroy.codec 31.0 (31) /System/Library/Components/VCH263Codec.component/VCH263Codec
    0x9fffc000 – 0x9fffefff Motion /Library/Frameworks/Motion.framework/Versions/A/Motion
    Model: PowerMac7,3, BootROM 5.1.8f7, 2 processors, PowerPC G5 (3.0), 2.5 GHz, 6 GB
    Graphics: ATI Radeon 9800 XT, ATY,R360, AGP, 256 MB
    Memory Module: DIMM0/J11, 512 MB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM1/J12, 512 MB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM2/J13, 512 MB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM3/J14, 512 MB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM4/J41, 1 GB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM5/J42, 1 GB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM6/J43, 1 GB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM7/J44, 1 GB, DDR SDRAM, PC3200U-30330
    Network Service: Built-in Ethernet, Ethernet, en0
    PCI Card: firewire, ieee1394, SLOT-3
    PCI Card: pciffff,30bf, sppci_video, SLOT-4
    Serial ATA Device: HDS722516VLSA80, 153.38 GB
    Parallel ATA Device: HL-DT-ST DVD-RW GWA-4082B,
    USB Device: Hub, , Up to 12 Mb/sec, 500 mA
    USB Device: USB Token, , Up to 1.5 Mb/sec, 500 mA
    USB Device: USB-HASP 1.12, AKS, Up to 1.5 Mb/sec, 500 mA
    USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
    USB Device: USB-PS/2 Optical Mouse, Logitech, Up to 1.5 Mb/sec, 100 mA
    USB Device: CT-0405-U, Tablet, Up to 1.5 Mb/sec, 100 mA
    USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
    FireWire Device: LaCie 1394 CDRW drive LUN 0, LaCie Group SA, Up to 400 Mb/sec
    FireWire Device: LaCie d2 Extreme LUN 0, LaCie Group SA, Up to 800 Mb/sec
    FireWire Device: LaCie 1394 Disk drive LUN 0, LaCie Group SA, Up to 400 Mb/sec
    FireWire Device: Io, AJA Video Systems, Inc., Up to 400 Mb/sec
    Jeremy Garchow replied 19 years, 10 months ago 4 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    September 28, 2006 at 12:20 am
    First, I would delete all the render files for that project (audio and video) and rerender. See what that does for you.
    Jeremy
  • Shawn Marshall
    September 28, 2006 at 1:38 am
    Thanks for the reply, Jeremy. I appreciate it.
    I should have mentioned that I did try deleting the render files, with no success. I deleted the render files out of my primary scratch disc, but it still crashed. When I trashed the preferences, the scratch disc defaulted to my startup disc, so I tried using that, and it still crashed. I switched back to my original scratch disc: crash-o-rama.
    Fudge.
    Shawn Marshall
  • Keith Koby
    September 28, 2006 at 2:45 am
    Is there a piece of media, a still or something that is about 23% of the way through your sequence that could be causing problems? Make sure you still have read/write access to all media, particularly around that point in the timeline. Just a guess.
  • Jeremy Garchow
    September 28, 2006 at 5:25 am
    Can you get anything else to export that’s not encoded with the Aurora codec? I’m wondring if it’s another ‘bad’ codec like the Avid ones. I thought deleting the render files might shake something loose, but since that didn’t work, try what Keith said and see what piece of media is about 23% in to your timeline. If it’s crashing at the same time, it’s usually a corrupt piece of media. QT7 handles things differently from QT6 and perhaps the difference is causing the crash. Is there anyway you can recapture any of these clips or are they all renders? If you can recapture, I’d give it a shot. Also, what plugins do you have installed? Any 3rd party plugs?
  • Shawn Marshall
    September 28, 2006 at 5:59 am
    Hi:
    Thanks for your suggestions.
    As a test, I set an IN mark at the start of the sequence and and OUT mark about halfway through (1 minute in). FCP quit about 50% into the export. So then I set the OUT mark at 40 seconds in, but that crashed too. Then I tried setting the IN mark at about 1 minute and the OUT mark at the end, around 2 minutes, and it crashed immediately.
    The weird thing is, some of the sequences, which are using the same type of MJPEG-A video, will export okay. I guess I can go in an start removing clips from the uncooperative sequences.
    Shawn Marshall
  • Jeremy Garchow
    September 28, 2006 at 4:36 pm
    It sounds like you have some corrupt media somewhere. I’d select the whole timeline that’s giving you problems, right click and take the media offline. Start reconnecting one by one and exporting until you get a bad one. It’s a pain but it’ll narrow down the problems.
    Any third party plug ins installed?
    Jeremy
  • Shawn Marshall
    September 28, 2006 at 6:37 pm
    Jeremy:
    Thanks again for your suggestions. I’ll examine the clips I’m using to see if I can isolate the problem.
    I’m not using any plugins of any kind in this project. I’ve never installed any third-party plugins that I know of. Will installed plugins cause problems if they’re not being used?
    Shawn Marshall
  • Jeremy Garchow
    September 28, 2006 at 7:10 pm
    Yes, plugins load up in FCP when the application is launched. There have been some problems with plug ins and FCP 5.1.x. namely, Zaxwerks and 3d flag are some. Boris has some trouble as well, but they have a patch and workaround.
    Jeremy
  • Tunaking
    September 28, 2006 at 11:16 pm
    I had a problem like this in previous versions of FCP (haven’t tried with 5.1.2 yet). But CYMK images (I had JPEGs) would drive FCP crazy. I converted them to RGB and the crashes stopped. Long shot, but check.
  • Shawn Marshall
    September 29, 2006 at 1:52 am
    Jeremy:
    Where do FCP plugins reside? After Effects has a folder called Plug-ins that lives in its application folder.
    I found a Plugins folder in the Final Cut Pro System Support folder in the Application Support folder in the Library folder on my system drive. There are a handful of things in there like Text Scrambler.bundle and Title 3D.bundle. Not much else.
    Thanks.
    Shawn Marshall
