Activity Forums Apple Final Cut Pro Legacy FCP 5.04 problem exporting ‘stills’
  • FCP 5.04 problem exporting ‘stills’
    Posted by Ben Ged low on February 16, 2006 at 8:00 pm
    Hi gang,
    I make a freeze frame. I render the freeze frame.
    I export as a ‘Quicktime conversion’ ‘still’. (Photoshop, JPG, Tiff – same results)
    SOME pictures are fine.
    SOME pictures are either blank white, or they have a thin veneer of white overtop, as if FCP has added a 40% white layer.
    I export EXACTLY the same way each time, the freeze frames pulled from the same original media.
    I get the same weirdly inconsistent results exporting a still right from the timeline.
    In all cases I first render the freeze frame or the clip from which the still is pulled.
    What is going on???
    Ben
    Michael Alberts replied 20 years, 6 months ago 2 Members · 1 Reply
  • Michael Alberts
    February 17, 2006 at 12:48 am
    There is no reason to make a freeze frame or render that freeze frame. Is there a specific reason why you are making a freeze frame. To export a still just load the clip into the viewer and Exprt/QT Conversion/Still. This method has never failed. I’ve probably exported 500 stills this way.
    Michael Alberts
    Ambidextrous Productions, Inc.
