Activity Forums Apple Final Cut Pro Legacy FCP 5.0.4 it wont start up
  • FCP 5.0.4 it wont start up
    Posted by Andrew on March 11, 2006 at 9:02 pm
    here’s what happened, the FW drive was unplugged while fcp was on, i got the warning that damage could happen, it didnt it works fine on another system, however the original system must now have a currupt file or pref, when i start it up it stars to go thru the start up and just shuts down, so what can i do to reset the app, so that it will at open, what do i need to trash. thanks
    Andrew replied 20 years, 6 months ago 3 Members · 4 Replies
  • Debe
    March 11, 2006 at 9:22 pm
    For info on trashing prefs, look at this site…
    https://www.lafcpug.org/trashing_fcp_prefs.html
    The following is a nifty little program that stores and trashes prefs for you. Just be careful backing up the first time. Make sure you’re backing up clean prefs.
    https://fcprescue.andersholck.com/
    For the record, a search for “trash preferences” would’ve yielded this same answer much much faster for you. Sometimes it’s hard to verbalize what you need, though, making searches tough. Next time, if you’re in a hurry, try a few different searches. You may find your answer much faster.
    debe
  • Shane Ross
    March 11, 2006 at 9:49 pm
    Debe…taht link to FCP Rescue no longer works.
    It is now hosted here, until the main site is up again:
    https://www.pistolerapost2.com/fcprescue
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Debe
    March 11, 2006 at 11:24 pm
    Actually, Shane, I checked it before I posted. It’s back up and running!
    debe
  • Andrew
    March 12, 2006 at 12:24 am
