Activity Forums Apple Final Cut Pro Legacy FCP 5.0.4 getting stuck on batch digitize then it crashes
  • FCP 5.0.4 getting stuck on batch digitize then it crashes
    Posted by Carlos Prio on January 4, 2006 at 2:54 pm
    Hello Guys,
    I am digitizing 84 clips of HDV into FCP 5.0.4 and it gets stuck in and around 7 minutes worth of material. I then Com. period out and it crashes… I have rebooted, copy and pasted clips into a new bin, deleted suspect clips, etc… but nothing seems to work. Next I will log clips again from scratch.
    Any ideas???? Do I trash prefs??? if so which ones??? Any help is much appreciated.
    Cheers,
    Prio
    Carlos Prio
    field dominance
    prio(at)fielddominance.com
    305/971-7037 ext. 208
    cell. 305/785-7746
    Miami, FL
    G5 Dual 2.0 w/ 2.5 gigs of ram, 160hd
    OSX 10.4.3
    FCP HD 5.0.4
    Lacie 320 & 1T d2 extremes
    BMD HD w/ Multibridge HD
    Cinema Display
    100a, fx1, hc-1, and waiting for the HVX200
    Michaelle Stikich replied 20 years, 8 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    January 4, 2006 at 3:37 pm
    The first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • Carlos Prio
    January 4, 2006 at 8:53 pm
    Thanks Matte! I have had a day from hell!!!! I did do the Prefs dump but I still have the problem. It seems that it is responding to a particular set of clips by just crapping out.. It will digitize some clips and compltely QUIT on others.
    I’ve tried relogging the clips, logging and then digitizing a clip, doing a “press play & manual digitize” … but nothing works… FCP continues to quit… I am at wits end!!!
    Any additional ideas???
    Carlos Prio
    field dominance
    cell. 305/785-7746
    Miami, FL
    OSX 10.4.3
    FCP HD 5.0.4
    Cinema Display
  • Michaelle Stikich
    January 6, 2006 at 6:34 pm
    One thing I have done in the past if I have not already started cutting the clips is to export a batch list of the problem clips and reimport it. Then capture. It seems that exporting a batch list cleans some of the bad data from the clips somehow. If you have a sequence that these bad clips link to, you could try exporting and EDL and recapturing that way.
    good luck!
    gir
