Activity Forums Blackmagic Design FCP 5.0.2, OS X 10.4.2, QT 7.0.1, BMD 5.0, Decklink Extreme Sound Problem
  • FCP 5.0.2, OS X 10.4.2, QT 7.0.1, BMD 5.0, Decklink Extreme Sound Problem
    Posted by Juan Salvo on August 17, 2005 at 2:49 pm
    We are in the process of upgrading all of our edit systems to the latest OS, FCP and BMD drivers. We’ve been running these versions for a week or two on our test system (Decklink HD Pro 4:4:4) and have been satisfied so far. Hence we’re going ahead with the upgrade on our other systems. I’ve just been testing the extreme system and have dicovered a little hick-up, the audio does not pass through the analouge outputs when in log and capture. I haven’t tested this on an SDI source yet, but it definately doesn’t work when in NTSC/PAL input. It would be nice to have this ability back into the card, it captures the sound just fine, but doeesn’t allow us to monitor when capturing. Any help would be appreciated.
    BTW, we are doing clean installs on all our systems, so this is not an upgrade issue.
    Juan
    Luke Maslen replied 21 years, 1 month ago 3 Members · 3 Replies
  • Lexerton
    August 17, 2005 at 3:01 pm
    I agree, Juan
    at the moment I monitor the audio from the deck but that’s not ideal if you want to work without a mixer.
    It does video out, so why not audio?
  • Juan Salvo
    August 17, 2005 at 4:36 pm
    I disabled the “Stable Black” output option, this has reactivated my analogue audio output from the decklink extreme.
  • Luke Maslen
    August 18, 2005 at 8:09 am
    Hi Juan,
    You have discovered the solution and this is the same as it was in previous versions of the driver. For a detailed understanding of what is happening during log & capture with the stable black option enabled, please see the technical note How to sync a deck with a DeckLink card.
    Regards,
    Luke Maslen
    Blackmagic Design
