Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.02 and ORIGINAL MPEG Encoder
  • FCP 5.02 and ORIGINAL MPEG Encoder
    Posted by Craig Ernst on September 13, 2005 at 4:40 am
    I just upgraded to FCP5.02 and cannot use the original MPEG encoder that came with DVDSP to export MPEGS. I like that MPEG encoder because it is fast and easy for simple client viewing. Any suggestions???
    Craig
    Dual G4 800
    1.5 RAM
    OSX.4.2
    QT 7.01 PRO
    DecklinkSP
    AttoUL3D
    FCP5.02
    Craig Ernst replied 21 years ago 2 Members · 2 Replies
  • Walter Biscardi
    September 13, 2005 at 1:42 pm
    That goes away with FCP 5 and DVDSP 4.0. You have to use Compressor to make an MPEG-2 now, yes it’s a bit annoying, but that’s the way it is.
    The best way to do this is to export a reference Quicktime movie from FCP. Quit FCP, then launch Compressor and do the compression. If you use the Export To Compressor function in FCP, compressor will run extremely slow as FCP is kept running in the background.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Craig Ernst
    September 13, 2005 at 3:52 pm
    Hi Walter,
    Please describe the simple steps to export a reference quicktime movie.
    Craig
    PS. I assume DVDSP 3 and 4 has a way to burn a simple “straight play” DVD as in DVDSP1.5. No menus, just play.
