Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.0.1 Won’t Open!!!
  • FCP 5.0.1 Won’t Open!!!
    Posted by Matt Fezz on May 9, 2006 at 12:03 pm
    Ok, heres the situation. FCP was working perfectly fine on my machine. I don’t open it for about 2 days, and now it will not open. I try to open it by any means (dock, application menu, quicksilver, project files, terminal) and the loading screen comes up no problems, however after I see “loading audio filters” it just closes. No windows initialize, no error messages, it just terminates.
    I have tried restarting, I have tried unmounting drives, I have tried uninstalling Quicksilver (installing it was the only change I have made to the system in the last 2 days). But none of these have helped. I cannot think of anything else and I REALLY need to get FCP running again.
    has anyone else encountered this problem or have any idea how to fix it?
    My final solution would be to re-install it but it it not somthing I would like to do..
    Walter Biscardi replied 20 years, 4 months ago 2 Members · 1 Reply
  • Walter Biscardi
    May 9, 2006 at 12:23 pm
    If you’re still running FCP 5.0, you really should be running 5.0.3 or 5.0.4 as those are much more stable. You can download the updates from the Apple Site.
    [Matt fezz] “I have tried restarting, I have tried unmounting drives, I have tried uninstalling Quicksilver (installing it was the only change I have made to the system in the last 2 days). But none of these have helped. I cannot think of anything else and I REALLY need to get FCP running again.”
    Have you trashed your FCP Prefs? Do that and then try to launch FCP.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
