Activity › Forums › Apple Final Cut Pro Legacy › FCP 5.0 to FCP 4.5 downward compatibility
  • Mark Raudonis
    August 2, 2005 at 2:59 pm
    Quick answer: Not easily.
    Workaround: Take 5.0 project, export as XML, import in 4.5.
    Right answer: Pay the money and upgrade!
    mark
  • Fred Miller
    August 2, 2005 at 3:14 pm
    It’s not really a money issue. It’s more of a comfort thing. My system is sooo solid right now. The thought of screwing with such a delicate balance is not that enticing. Maybe I’ll just buy another drive and have two separate bootable configs.
    G5 2Gg Dual
    1.5Gg RAM
    Panther
    ATTO UL3D
  • Jeremy Garchow
    August 2, 2005 at 4:24 pm
    Fred, that’s the best decision you’ll make. Edit your client’s projects with FCP5, and do you stuff with FCP 4.5. Also, you will be installing everything correctly as a fresh install, instead of upgrading the OS & FCP. You will also begin to see that you don’t need to be so scared of FCP5/tiger.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
