Activity Forums Apple Final Cut Pro Legacy FCP 5.0 Effects Plug-in
  • FCP 5.0 Effects Plug-in
    Posted by Rbfineline on September 15, 2005 at 5:53 pm
    In your opinion, what is the most powerful effects plug-in you’ve found for Final Cut Pro 5.0? Would you recommend Boris or something else keeping in mind ease of use?
    Rbfineline replied 21 years ago 3 Members · 5 Replies
  • Jerry Hofmann
    September 16, 2005 at 3:05 am
    The question should include what you need to do I think…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Rbfineline
    September 16, 2005 at 1:31 pm
    I produce broadcast commercials as well as 28:30 broadcast programs. I need the effects to be cutting edge, crisp and play well with FCP.
  • Chris Poisson
    September 16, 2005 at 1:44 pm
    Boris Continuum Complete is a pretty good start. I also like Joe’s Plugins, Eureka! and the Nattress sets.
  • Jerry Hofmann
    September 16, 2005 at 1:46 pm
    Actually, in this arena, there aren’t “bad” effects pkgs… I do like Natress’s stuff as well as Boris’ products… Don’t forget what you can do with Motion too!
    Jerry
  • Rbfineline
    September 16, 2005 at 5:54 pm
    I do like Motion 2 the more I work with it. Boris was very cumbersome when working within Avid. (but then so was everything else). Is it easier in FCP?
    I’ve not dealt with Natress- what can you tell me about it?
    Ron
