Activity Forums Apple Final Cut Pro Legacy FCP 5.0 Custom Keyboard
  • FCP 5.0 Custom Keyboard
    Posted by Les Kaye on May 29, 2005 at 9:51 pm
    I’m trying to map the Tab key to navigate to the next and previous events. Since TAB by itself is unavailable, I’ve tried Shift & Option keys as the modifier keys with Tab. Doesn’t work. Suggestions?
    Les Kaye replied 21 years, 3 months ago 2 Members · 2 Replies
  • Gavin Stokes
    June 1, 2005 at 9:18 am
    Les,
    This may be related to an OS-level problem. The general key remapper at the OS level fails to deactivate the normal function of Tab and some other keys while you’re setting the hotkey for a function, making it impossible to remap them. There are also a lot of problems caused by conflicts between old Emacs control keys and keys that the user defines.
    There’s a lot of cleanup that needs to be done in this area.
    Regards,
    Gavin
  • Les Kaye
    June 10, 2005 at 2:00 am
    [stokestack] “There’s a lot of cleanup that needs to be done in this area.
    And I know just the guy who can do it! Thanks Gavin, mucking my way about.
    -Les
