Activity Forums Apple Final Cut Pro Legacy FCP 5.0 black screen
  • FCP 5.0 black screen
    Posted by Marcus Ionis on July 6, 2005 at 4:08 pm
    g5 2.7gnz
    2.5gigs ram
    fcp 5
    kona2
    I have some 720 59.94 HD footage on my system. When I’m playing the footage it looks great in the record viewer, but when I park the timeline cursor the screen turns black. Even if I move at single frame increments, the screen is still black.
    Any suggestions???
    Marcus Ionis
    Marcus Ionis
    John Murillo replied 17 years, 10 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    July 6, 2005 at 5:29 pm
    the record viewer? you mean the Canvas after placing clips in a sequence? Are you having to render these clips in the sequence? or? How do they playback in the Viewer?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Marcus Ionis
    July 7, 2005 at 7:08 pm
    Yes…the canvas after placing the clips in the sequence.
    “Are you having to render these clips in the sequence? ”
    No…they fit perfectly in the sequence….
    “How do they playback in the Viewer?”
    They play fine in the Viewer.
    Also all the 1080 frequence play fine in both the Canvas and my HD monitor.
    My ouput setting from the card match my sequences.
    Hope you have more suggestions
    Marcus Ionis
  • John Murillo
    October 29, 2008 at 7:59 pm
    try to go to the Sequence Settings and the Render Control Tab and switch the Codec from “same as sequence codec” to ProRes
    worked for me, hope this helps
