Activity Forums Apple Final Cut Pro Legacy FCP 5 Slow Startup
  • FCP 5 Slow Startup
    Posted by Rob Hughes on March 10, 2006 at 1:53 pm
    Hi – i’m having problems with a slow startup of FCP 5. It takes around 1-2 minutes to start up each time.
    It didn’t do this when i first installed it.
    I searched on here and found this post below, but wasn’t sure what it meant – can anyone explain this, or suggest why my system takes so long to start?
    System: dual G5 1.8’s. 1.5GB RAM, Latest OS, FCP 5
    Cheers.
    Since yesterday, FCP takes a good long time to startup. I don’t think it has anything to do with corrupt preferences as versions 4.1 and 4.5 are doing the same thing. Once they finally load they work fine. Has any one experienced this?
    jmf
    Respond to this post Return to posts index
    Date: Jan 11, 2006 at 6:16:25 am
    Subject: Re: FCP startup problem
    Okay I found it. It was the Quicktime mpeg2 component.
    jmf
    p.s. apologies if you find this twice – i wasn’ sure if it would get noticed when i just responded to the original post from back in jan.
    Jack Fox replied 20 years, 6 months ago 2 Members · 1 Reply
  • Jack Fox
    March 10, 2006 at 3:27 pm
    It seemed to happen with the last update of Quicktime, and I knew I found the cause when I uninstalled the mpeg2 component (note that if haven’t purchased mpeg2 from Apple you need to look elsewhere for an explanation) and FCP loaded much quicker. However, quicker wasn’t better, as the consequence was that FCP could no longer handle mpeg2 segments in the timeline. So I reinstalled mpeg2 and now wait patiently while FCP takes longer to load. If you find a real solution please let us know.
    jmf
