Activity › Forums › Apple Final Cut Pro Legacy › FCP 5 Scale, rotate quality settings etc..
  • FCP 5 Scale, rotate quality settings etc..
    Posted by Paul Nevison on November 7, 2005 at 4:16 pm
    hey guys
    where can i find the panel to adjust the scale and rotate settings in fcp 5. ive tried searching the online manual and couldnt find it
    thanks
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
    BMD Decklink Extreme
    Peter Mcauley replied 20 years, 10 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    November 7, 2005 at 4:19 pm
    It’s in the Sequence settings… there’s a tab there to click for this “video processing” it’s a popup menu there.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Paul Nevison
    I may have found it – in the sequence settings in the video effects tab…ive set motion effects to best – but there doesnt seem to be that much of an improvement around the edges of a spline im moving in 3D space.
    am i looking in the wrong place for this control?
    thanks
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
  • Paul Nevison
    November 7, 2005 at 4:22 pm
    thanks Jerry,
    found it….i guess it’s not the quantum leap i had been hoping for…looks like it’s still out to third party apps for movement etc…
    G5 DP 2.0
    2.0G RAM
    OS 10.4.2
    QT 7.0.3
    FCP 5.0.3
  • Kevin Monahan
    November 7, 2005 at 10:03 pm
    Rendering has become a bit more complex these days. Not only does your video processing have to set to best, you also have to have your RT pop up in Safe RT and Full Quality playback, not Dynamic. I also suggest that you check the dark green “FULL” bar and re-render the piece.
    Above all, make sure that you monitor all rendered fx on a video monitor. If you are not using a video monitor in your workflow, then you will never be able to get a read on the final quality of your piece.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Peter Mcauley
    November 8, 2005 at 1:18 pm
    Remember that even when you set it to “best” this only applies to scale and position. Soon as you adjust rotation of any kind , even though it is set to “best” you will only get “normal out of it. Rotation was not included in the new rendering algorithyms. Check the knowledge base for more info. Kind of a bummer really.
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.4.2
    FCP 5.02
    QT 7.03
    Kona 2 v1.1.4 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
