Activity › Forums › Apple Final Cut Pro Legacy › FCP 5 Plugins not recognized
Posted by Andy Field on May 23, 2005 at 4:03 pmOld FCP Plugins (boris CHV CGM etc) aren’t showing up in FCP 5) have tried putting them in Library/Application Support/Final Cut Pro System support/Plugins — – they won’t show up….also Boris text 3d isn’t there – read a recommendation to put it in a folder called Boris and reload program – no luck – any ideas? Thanks Andy Field
Andy Field replied 21 years, 3 months ago 6 Members · 8 Replies -
Andy Field
May 23, 2005 at 5:04 pmOn line with Apple – seems as this may be a problem with the upgrade version of FCP5 from earlier.
If you have this problem here’s what they suggest.
1. Go to Boot drive/library/receipts/finalcutpro.pkg
delete Finalcutpro.pkg in that folderALSO take the Plugins folder and move to desktop Library/Applicationsupport/final cup pro support/plugins
Repair permissions
Restart
Get FCP5 install disk – and reinstall JUST final cut pro (when you get to options for others Motion etc – uncheck all)
Once you reinstall – just for good luck – repair permissions again
reopen Final Cut 5
The boris folder should be in the effects/generator folder and all sould be well.
BUT – carefully reinstall third party plugins one at a time – I put all of them back in – boris Title 3d disappeared again – pulled them back out – and put back one at a time – if one plug in is not compatible it seems to bring the entire plug in folder down.
Derek Woods
May 23, 2005 at 8:58 pmandy,nice job-did you figure out which plugins are bad?
I’m getting a new g5 and a seperate version of fcp studio thursday, so i want to get ready for a long weekend!! -
Bill Portune
May 23, 2005 at 9:23 pmThanks, saved me a bunch of time. It turned out to be the Automatic Duck Pro Import that was crashing the plugin folder.
Andy Field
May 24, 2005 at 1:56 amI’ve now reloaded everything but the Boris Red FCP plugins – can’t say for sure that’s what caused the problem but will keep experimenting.
All seems well – improvements in Motion and Live Type are amazing – take time to use the tutorial DVD’s – loaded with useful hints….
Chris Paul
May 24, 2005 at 4:28 pmIf you are having problems with Boris RED the problem might be corrupt fonts. I had exactly that problem- for some reason the bad fonts did not show up until after the FCP5 upgrade. I used Font Doctor- took a while and had to re-run it several times but now Boris is happy.
Chris Paul
POV -
Bud Solem
May 31, 2005 at 5:46 pmHow do you repair persmissions? I did a help search withing the OS (Tiger) and FCP5 and can’t find anything. Thanks.
Andy Field
June 1, 2005 at 1:44 pmif you can’t find the program in your Utilities Folder – do a search for DISK UTILITY – open it – select your hard drive and then click repair permissions
