Activity › Forums › Blackmagic Design › FCP 5 long capture problem bmd 5.02b
  • FCP 5 long capture problem bmd 5.02b
    Posted by Paul Provost on June 10, 2005 at 4:23 am
    anyone able to capture more than 45 min 10 bit SD/sdi in fcp 5 & tiger. over and over at about 45 min capture stops and the capture confirmation window opens asking if you want to capture the clip.
    if you confirm the window closes and the media is gone. if you cancel. the clip is in the browser, but the length of the clip is where the capture stopped.
    decklink extreme
    ps I have a second boot drive in the dual g5 with a working 10.3.8 system so all the gear is working.
    re installed drivers, trashed prefs etc on the tiger system – no luck
    Paul Provost replied 21 years, 3 months ago 4 Members · 8 Replies
  • 8 Replies
  • Paul Provost
    June 10, 2005 at 4:24 am
    this is a fresh install of everything on the second drive including final cut studio
  • Paul Provost
    June 10, 2005 at 4:44 am
    i’m capturing blackmagic dv – ntsc
    not 10 bit – i will try that to see if it’s confined to the 10 bit to dv easy setup.
  • Luke Maslen
    June 10, 2005 at 7:21 am
    Hi Paul,
    Please check that this isn’t caused by your energy saver settings as I remember a similar problem from some while ago. It will be interesting to see if your energy saver settings are set to 45 minutes.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Sean Oneil
    June 10, 2005 at 8:31 am
    I haven’t done anything but batch capture yet, but my fellow editor complained that his captures using log and capture were stopping at around 20 minutes every time – even though his out point was much further along.
    I’ll tell him to check the energy saver.
  • Sean Oneil
    June 10, 2005 at 6:28 pm
    His energy saver was turned off and the option to put disk drives to sleep was also off. His screensaver was set for 2 hours. So that’s definately not the cause.
  • Paul Provost
    June 12, 2005 at 3:50 am
    same here – not my energy settings. removed and re-installed drivers and still no luck – stops at about 45 min.
  • Lincoln Sparks
    June 13, 2005 at 7:23 pm
    i’m seeing the exact same problem with the Aja IO on clips as short as 5 minutes. what type of storage are you capturing to? i seem to only see this when capturing to the XSAN, not to a HUGE SCSI array.
  • Paul Provost
    June 14, 2005 at 2:37 pm
    firewire 800 raid getting a write speed of 171 frames 10 bit ntsc SD with speed test! should be fast enough…
