Activity › Forums › Apple Final Cut Pro Legacy › FCP 5 Intel concern
David Roth weiss
August 13, 2009 at 4:41 pm[Zane Barker] “Wayne his old machine is a G5, so he cannot run FCS3 on it. FCS3 is Intel only. “
Correct, I had a typo and meant to say FCS2 and FCP6 in my post. FCP6 is the only version that will work on both Jim’s G5 and his new MacPro, so whatever the cost, that’s the best solution for him now if he wishes to continue using both computers for editing on a single project.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
David Roth weiss
August 13, 2009 at 4:43 pm[Jim Hoey] “FCS2 and/or 3? Your 1st post said FCS3.”
I meant to say FCS2 with FCP6 on both computers. That’s your only hope of using the same software on both computers.
David Roth Weiss
Director/Editor
Jim Hoey
August 13, 2009 at 4:49 pmDo you think there be any problem with capturing to an external drive on the Intel and then working with the drive on the G5 IE: codec issues? Will the Leopard or intel cause any conflict with the G5? I ask because this way I can use Compressor on the G5 for projects. My concern is corrupting the G5 which is a dedicated suite with a lot of vital current templating. I have backed up. I just want to avoid any problems if possible. Also, if i want to buy the FCS 3 FCP 6 upgrade where can I do it?
Thanks guys! -
Mark Maness
August 13, 2009 at 5:01 pmI am aware of that.
But you have to look at this in this manner. If this is your bread and butter, what’s more important to you, work arounds or time saving features that may make you more money.
I understand the economy and how its affected everyone but times are tough and you need to find something that makes you look better to your clients. Its a risk but that’s business.
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
Jim Hoey
August 13, 2009 at 5:09 pmHi Wayne,
Please read Zane’s post on this subject. It will clear up why I am asking these questions.
Jim -
Michael Sacci
August 13, 2009 at 5:46 pmJim, there should be no issue capturing with one version of FCP and editing on an older version. As long as you stay away from new codec, if you get FCP6 for the MBP you don’t want to be capturing ProRes since FCP5 doesn’t have that codec, but to capture DVCProHD you can go back and forth without issue. If you do basic editing on the MBP you can use xml to get the edits into FCP5.
As with everything we do a little forethought goes along way. Think through and test the process and you can make it happen. If you are not swapping projects back and forth I would go up to FCS3 for the MBP to get Compressor 3 and save the money. IF you want to be going back and forth with full projects then FCP6 on both is the way to go.
Zane Barker
August 13, 2009 at 6:20 pmI say upgrade to the new FCS3 and edit with your new MacBook Pro. That laptop is acutlay faster then your old G5.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Jim Hoey
August 13, 2009 at 6:21 pmThanks Michael,
I capture from a Sony DSR 11 unit or our SONY DSR camera to MBP. It currently runs all FCP 5 software excepting Compressor 2. All I really need the MBP for is to capture in the field to save time on projects coming home from the field. I have already been able to use the external drive I save to in order to use Compressor on the G5. I think the FCP 6 is a good option. It sounds like what you are saying is FCP 5 on the MBP and on the G5 will be fine to take external back and forth. Will this be the same for Live text and/or Motion projects (any other FCS software? -
Scott Sheriff
August 13, 2009 at 9:35 pmSlightly OT
When you buy FCS2 or 3,do you have the right to install on as many computers as you want?
I assumed (maybe incorrectly) that for the purchase price, you were paying for one license use.
I saw several posts in this thread recommending using one license copy on several computers, technical issues aside.
Any thoughts on this? -
Jim Hoey
August 14, 2009 at 3:26 pmmy understanding is that when you buy a license you may use it on a tower and a laptop if you own both cpu’s.
