Activity › Forums › AJA Video Systems › FCP 5 improves DVCPro HD Batch Capture
  • FCP 5 improves DVCPro HD Batch Capture
    Posted by Walter Biscardi on June 22, 2005 at 3:29 pm
    Hey all,
    Just wanted to let you know that we’re batch capturing 6 epsiodes of a series in DVCPro HD and have zero “timecode breaks” and other timecode anomolies that would appear with almost every DVCPro HD Batch capture in FCP 4.5. We’re running our 1200A via Firewire using the DVCPro HD 720/60 Easy Setup.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Walter Biscardi replied 21 years, 3 months ago 6 Members · 15 Replies
  • 15 Replies
  • Aaron Neitz
    June 22, 2005 at 5:33 pm
    good to hear. my last batch capture from DVCPRO HD was a long night of manual adjustments
  • Jeremy Garchow
    June 22, 2005 at 7:09 pm
    Keep the good news coming.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Walter Biscardi
    June 22, 2005 at 7:15 pm
    [JeremyG] “Keep the good news coming.”
    Ok, I will.
    My OMF Imports from AVID are working perfectly dead on and the transitions are coming in more accurately. The series we’re conforming is cut for SD on an Adrenaline, then I get the OMF and conform the HD show. With FCP 4.5 we had a lot of slippages of audio sync and some transitions just not coming over right at all. With FCP 5, so far all is spot on and I don’t have to touch any of the transitions.
  • Dan Riley
    June 22, 2005 at 8:56 pm
    Walter,
    Is this using the Automatic Duck OMF translation software
    or just a straight OMF2 to FCP ?
    Dan
  • Walter Biscardi
    June 22, 2005 at 11:05 pm
    [Danrnw] “Is this using the Automatic Duck OMF translation software
    or just a straight OMF2 to FCP ?”
    It’s using the Duck. You have to use the Duck for an OMF import from AVID.
  • Dan Riley
    June 23, 2005 at 2:27 am
    That’s what I thought, but since you only said OMF….
    Dan
  • Olivier Jean
    June 24, 2005 at 2:00 pm
    what kind of throughput do you get on your huge raid??
    Regards
    Olivier Jean
    Powermedia Systems
    Sydney Australia
  • Olivier Jean
    June 24, 2005 at 2:06 pm
    Hi Walter,
    so the automatic duck is working well with FCP 5?
    did you have to use the name trick ” to get the Aja drivers loaded?
    and lastly are you using tiger?
    I remembered a few weeks ago you mentioned
    that the duck wasn’t working for you.
    Regards
    Olivier Jean
    Powermedia Systems
    Sydney Australia
  • Walter Biscardi
    June 24, 2005 at 7:25 pm
    [olivier jean] “so the automatic duck is working well with FCP 5?”
    These particular projects had already been imported to FCP 4.5 and then upgraded to FCP 5.0. But so far all is going well and the recaptures in FCP 5.0 are much more accurate than they were in FCP 4.5.
    [olivier jean] “did you have to use the name trick ” to get the Aja drivers loaded?”
    I honestly have not heard about that one. I just installed the 1.1.1 drivers and they went right in.
    [olivier jean] “and lastly are you using tiger?”
    Yep, 10.4.1 and QT 7.0.1
    [olivier jean] “I remembered a few weeks ago you mentioned
    that the duck wasn’t working for you.”
    I could not get an OMF to convert correctly using Tiger, but Wes Plate at the Duck could not duplicate my problems. So I’m going to try again in a few days when I get a few more OMF’s sent to me from another AVID project.
  • Jeremy Garchow
    June 24, 2005 at 9:51 pm
    Well, using the K2 system test 2GB file size and uncompressed 1080i 10 bit setting, running Raid 3, and the disk is over 70% full (680GB used out of a possible 930GB), I get 167MB write & 175MB/sec Read. When the disk is empty i get well over 200 MB/sec. Does that help? Raid ) would go even faster, but I need the Raid 3 protection.
    Jeremy
