Activity Forums Apple Final Cut Pro Legacy FCP 5 freezes during capture
  • FCP 5 freezes during capture
    Posted by Alfragamus on April 27, 2007 at 4:28 pm
    Help!! I’m having a problem where FCP and my entire Mac will freeze (sometimes) during capture and export. It locks up to the point that all I can do is power down the Mac to reboot. I am trying to capture DV through a DSR-11 connected via Firewire. This has happened with three different drives (2 Maxtor Onetouch III 600GB & 1 Maxtor Onetouch III 500GB). All of which work fine on other computers. I have been using this setup with these drives and deck for over a year with no problems. Nothing has changed. The problem also seems to be erratic. It won’t lock up for a while (a couple of hours) and then all of a sudden, all it will do is lock up.
    I am running a Mac dual 2.5 G5 w/ 2 GB of RAM. Mac OSX v 10.4.9, FCP v 5.0.4.
    I have tried:
    -Trashing prefs
    -Reinstalling FCP
    -Removing all peripherals except external HD
    -Removing all third party cards
    -Running Apple Hardware tests (all passed)
    Adam Miller
    Midge Galligan replied 17 years, 7 months ago 4 Members · 6 Replies
  • Arty Gold
    April 27, 2007 at 7:51 pm
    same thing…the only difference is it’s effecting my log and capture
    it wil stop and go …basically looks like the video is stuttering and going
  • Jicky Ferrer
    January 26, 2008 at 11:53 pm
    Did you ever have a solution to this problem? My G5 seems to be suffering the same fate.
  • Alfragamus
    January 27, 2008 at 5:09 pm
    Sadly, no. Tech guy not figure out if it was the logic board or the processor that was bad – both costing about $1000 to replace. So I just got a used G5 on ebay for around that same price. The old one is still limping along and is OK for short usages and non intensive apps.
  • Jicky Ferrer
    January 28, 2008 at 6:22 am
    Here is what my tech guy recommended. I had Norton’s loaded and that is when my problem began. He trashed Norton’s and reloaded my operating system. At least that is what he told me he will be doing. I will be picking up my system this week to find out if it works. The other thing I learned from NAB 07 Mac Troubleshooting was that you should create a Pristine test account (log-on). Defer to it as a resource when your regular log-on is experiencing problems. It could be something that is inherent in your profile.
  • Alfragamus
    January 28, 2008 at 5:05 pm
    Never had norton installed. And I ruled out both hard drive and software issues by installing a different newly reformatted hard drive and loaded everything on it bare bones. Still had the same problems.
  • Midge Galligan
    January 30, 2009 at 12:20 am
    Hi
    My Macbook Pro is connected to two external hard drives one with an 800 fire wire and one with 400.
    everything has been going fine then suddenly the other day it keeps freezing when I capture video.
    It also doesn’t recognize one of the drives now. It just doesn’t load up and I don’t think anything happened to it.
    I have trashed the prefs and undone all the cables and re-booted.
    HELP
    Midge Galligan
